[mapserver-dev] Python-MapScript: Passing Geometry
Fabian Schindler
fabian.schindler at eox.at
Mon Dec 10 02:24:43 PST 2012
Hi devs,
In our application we use MapScript to configure a WMS service to
service satellite imagery. One feature is to display the outlines of the
images using a vector layer. We are currently doing this using an SQL
connection to the database.
We found this prone to errors as the query also involved a time span
which is not time zone aware. Also, we use Djangos ORM to set up our
database layout, so we have to apply changes to the custom query SQL
every time the data models receive changes.
So I'm looking for alternatives and I found the FEATURE object would
suit our needs, as we already have retrieved the geometry from the
database, which we could serialize as WKT. Unfortunately, I could not
find any `featureObj` or the like in MapScript and the `layerObj` does
not have a `feature` property.
Do I miss something here? Is there another possibility to easily pass
geometry too a `layerObj` without relying on files on the disk or a
database connection?
Thanks,
Fabian
