[mapserver-dev] Encoding on WFS served from PostgreSQL by Mapserver.
Morten Olsen Lysgaard morten at lysgaard.no
Sun Feb 5 17:09:04 EST 2012
On 02/05/2012 10:30 PM, Yves Jacolin wrote:
> You can check the client_encoding parameter on the postgresql side or test
> *wfs_encoding*
>     (Optional) XML encoding for all XML documents returned by the
>     server. The default is ISO-8859-1.
> In the METADATA of the WEB object.
Worked brilliantly! Thanks a bunch =)
