[mapserver-dev] [ Mapserver 6.0.2 ] - libgdal.so | [shp2img] Error 1
Salvatore Larosa
s_larosa at libero.it
Mon Feb 20 16:41:00 EST 2012
I get an error while building mapserver 6.0.2,
at "make" I get the following:
/usr/local/lib/libgdal.so: undefined reference to
`GEOSGeom_getCoordinateDimension'
collect2: ld returned 1 exit status
make: *** [shp2img] Error 1
More info:
$ gdal-config --version
1.9.0
$ gdal-config --libs
-L/usr/local/lib -lgdal
MapServer is now configured for
-------------- Compiler Info -------------
C compiler: gcc -g -fPIC -Wall
C++ compiler: g++ -g -fPIC -Wall
Debug: -g
Generic NINT:
-------------- Renderer Settings ---------
OpenGL support:
zlib support: -DUSE_ZLIB
png support: -DUSE_PNG
gif support: -DUSE_GIF
jpeg support: -DUSE_JPEG
freetype support: -DUSE_FREETYPE
iconv support: -DUSE_ICONV
AGG support: internal
SVG Symbol support: -DUSE_AGG_SVG_SYMBOLS
Cairo (SVG,PDF) support:
KML support:
-------------- Support Libraries ---------
Proj.4 support: -DUSE_PROJ
Libxml2 support: -DUSE_LIBXML2
FriBidi support:
Curl support: -DUSE_CURL -DUSE_CURLOPT_PROXYAUTH
FastCGI support:
Threading support: -DUSE_THREAD
GEOS support: -DUSE_GEOS
XML Mapfile support:
XSLT support:
EXSLT support:
-------------- Data Format Drivers -------
PostGIS support: -DUSE_POSTGIS -DPOSTGIS_HAS_SERVER_VERSION
ArcSDE support:
OGR support: -DUSE_OGR
GDAL support: -DUSE_GDAL
Oracle Spatial support:
-------------- OGC Services --------------
WMS Server: -DUSE_WMS_SVR
WMS Client: -DUSE_WMS_LYR
WFS Server: -DUSE_WFS_SVR
WFS Client: -DUSE_WFS_LYR
WCS Server: -DUSE_WCS_SVR
SOS Server: -DUSE_SOS_SVR
-------------- MapScript -----------------
PHP MapScript: yes
Any hint?
thank you!
SL
View this message in context: http://osgeo-org.1560.n6.nabble.com/Mapserver-6-0-2-libgdal-so-shp2img-Error-1-tp4489060p4489060.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
