[mapserver-dev] classObj.setText, text must be quoted
Tamas Szekeres
szekerest at gmail.com
Thu Feb 23 14:48:33 EST 2012
Steve,
I'm still uncertain about the most reasonable solution here. Forcing the
requirement to quote strings in a mapfile looks fairly straightforward to
use, but quoting strings in classObj.setText is a bit awkward. Wouldn't
that be a solution to add quotes around a string in the interface file
(class.i) if that hasn't yet been added by the user?
Best regards,
Tamas
2012/2/22 Lime, Steve D (DNR) <Steve.Lime at state.mn.us>
> msyytext/msyystring isn’t being truncated per se it’s just that a string
> with spaces is not valid in a mapfile. That is:****
> TEXT Sample Text****
> would normally generate a parsing error. In this case only the string
> Sample Text is being parsed and without the quotes only the text ahead of
> the space is matched. I suppose it’s possible to relax the string matching
> expression in maplexer.l when in EXPRESSION_STRING context to allow spaces
> and other characters.****
> Steve****
> *From:* Tamas Szekeres [mailto:szekerest at gmail.com]
> *Sent:* Wednesday, February 22, 2012 9:14 AM
> *To:* Lime, Steve D (DNR)
> *Cc:* mapserver-dev at lists.osgeo.org
> *Subject:* Re: [mapserver-dev] classObj.setText, text must be quoted****
> Checking the first character instead of the length would be a good
> solution for MapServer 6.0 and the earlier versions. But I'm not sure how
> this would solve the same problem in trunk. Actually when getSymbol is
> failing we can obtain only a truncated text from msyytext/msyystring so we
> cannot use this to assign the value to the corresponding property. We
> should probably find out the reason why msyytext/msyystring is truncated
> in this case or use the "value" argument of loadExpressionString
> instead. Does this make sense?****
> Best regards,****
> Tamas****
> 2012/2/22 Lime, Steve D (DNR) <Steve.Lime at state.mn.us>****
> In 6.0 class->text is a true expressionObj, not a string as in previous
> versions so at least via SWIG setText() calls msLoadExpressionString(). I
> think there could be a bug in that function at line 2169 (in trunk). Older
> versions of that function treat the input string as a the expression if
> parsing doesn't detect a delimited type. So does this version but in a
> different way:
> // trunk
> exp->type = MS_STRING;
> exp->string = msStrdup(msyystring_buffer);
> // 5.6 branch
> if((strlen(value) - strlen(msyytext)) == 2)
> exp->string = strdup(msyytext); /* value was quoted */
> else
> exp->string = strdup(value); /* use the whole value */
> I've got a feeling this has to do with escaping quotes where
> msyystring_buffer contains the escaped text. Perhaps we could do something
> like:
> if(... if first char in value is not a single or double quote ...)
> else
> Alan, does this make sense or is there another way to know that escaping
> was processed?
> Steve****
> *From:* mapserver-dev-bounces at lists.osgeo.org [
> mapserver-dev-bounces at lists.osgeo.org] on behalf of Tamas Szekeres [
> *Sent:* Tuesday, February 21, 2012 4:09 PM
> *To:* mapserver-dev at lists.osgeo.org
> *Subject:* [mapserver-dev] classObj.setText, text must be quoted****
> Hi Devs, ****
> By using the following mapscript example:****
> *// creating a new map from scratch*****
> * mapObj map = new mapObj(null);*****
> * // adding a layer*****
> * layerObj layer = new layerObj(map);*****
> * // define the class*****
> * classObj classobj = new classObj(layer);*****
> * classobj.setText("Sample Text");*****
> * Console.WriteLine("Sample Text -> " + classobj.getTextString());***
> * classobj.setText("Sample T");*****
> * Console.WriteLine("Sample T -> " + classobj.getTextString());*****
> * classobj.setText("\"Sample T\"");*****
> * Console.WriteLine("\"Sample T\" -> " + classobj.getTextString());**
> I got the following output (from trunk):****
> Sample Text -> "Sample Text"****
> Sample T -> "Sample"****
> "Sample T" -> "Sample T"****
> 6.0 branch produces this:****
> Sample Text -> "Sample"****
> Do we have a requirement that the texts must be quoted which is passed to
> *classobj.setText?*****
> Best regards,****
> Tamas****
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120223/be90e62f/attachment-0001.html
