[mapserver-dev] python mapscript compile causes error
Guillaume Sueur
no-reply at neogeo-online.net
Wed Feb 29 03:29:49 EST 2012
Le 28/02/12 21:52, Umberto Nicoletti a écrit :
> This ticket should have information and a patch to help you fix your issue:
> http://trac.osgeo.org/mapserver/ticket/3940
Exact. Same workaround as the one I've found in mapscript.py
> Which python version are you using, btw?
2.6
I did test the pymodule.i patch and it worked well for me. It's worth
than having to patch mapscript.py everytime you make a new build of it.
I hope to see it committed soon ;-)
Thanks for your help, the bug title wasn't clearly related to the
behaviour.
Best
Guillaume
> On Tue, Feb 28, 2012 at 5:32 PM, Guillaume Sueur
> <no-reply at neogeo-online.net <mailto:no-reply at neogeo-online.net>> wrote:
> Hi list,
> I did my own compile of mapscript after some modifications in
> mapogcsld.c file, and if the things went well, I ran into two
> similar errors provided by mapscript.py but not directly connected
> to the modifications I've made.
> On lines 823 and 1371, instead of having __init__(self, *args) like
> in mapscript genuine version, there was respectively :
> def __init__(self, layer = None):
> and
> def __init__(self, map = None):
> which caused following lines using args to raise an exception.
> I don't understand why it occured (maybe swig configuration or
> whatever) and would appreciate any clue about this.
> Best regards
> Guillaume
> _________________________________________________
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
> http://lists.osgeo.org/__mailman/listinfo/mapserver-dev
> <http://lists.osgeo.org/mailman/listinfo/mapserver-dev>
