[mapserver-dev] Re: MapServer trunk Redhat 6.2 Build - require no space between `-L' and `-lc'
thomas bonfort thomas.bonfort at gmail.com
Mon Jan 2 09:46:49 EST 2012
I changed the configure script to not add an empty -L for libiconv.
thomas
On Mon, Jan 2, 2012 at 15:35, thomas bonfort <thomas.bonfort at gmail.com> wrote:
> that seems reasonable, -L is expecting a directory. can you look in
> Makefile which dependency added this -L ?
> On Mon, Jan 2, 2012 at 15:31, Smith, Michael ERDC-CRREL-NH
> <Michael.Smith at usace.army.mil> wrote:
>> Thomas,
>> After the libtool changes, I'm seeing the error
>> libtool: link: require no space between `-L' and `-lc'
>> Our config is
>> [gridusr at rsgisvmw05 mapserver]$ cat build.grid
>> ./configure \
>> --without-tiff \
>> --with-agg \
>> --with-threads \
>> --with-jpeg \
>> --with-png \
>> --with-freetype \
>> --with-proj \
>> --with-ogr=/home/gridusr/local/bin/gdal-config \
>> --with-gdal=/home/gridusr/local/bin/gdal-config \
>> --with-wfs \
>> --with-wcs \
>> --with-kml \
>> --with-sos \
>> --with-wmsclient \
>> --with-wfsclient \
>> --with-curl-config=/usr/bin/curl-config \
>> --with-xml2-config=/usr/bin/xml2-config \
>> --with-libiconv \
>> --with-oraclespatial=/home/gridusr/local/instantclient_11_2 \
>> --enable-debug \
>> --enable-point-z-m
>> And the specific libtool line is
>> libtool: compile:  gcc -c -I/home/gridusr/local/include -Wall
>> -DUSE_POINT_Z_M -DUSE_WMS_LYR -DUSE_WFS_LYR -DUSE_SOS_SVR -DUSE_LIBXML2
>> -DUSE_CURL -DUSE_CURLOPT_PROXYAUTH -DUSE_KML -DUSE_WCS_SVR -DUSE_WFS_SVR
>> -DUSE_WMS_SVR -DUSE_ORACLESPATIAL -DUSE_GDAL -DUSE_OGR -DUSE_THREAD
>> -DUSE_PROJ -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
>> -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS
>> -DGD_HAS_GET_TRUE_COLOR_PIXEL -DUSE_ICONV -DUSE_GIF -DUSE_PNG -DUSE_ZLIB
>> -DUSE_FREETYPE -DHAVE_VSNPRINTF -DNEED_STRLCPY -DNEED_STRLCAT -DNEED_STRRSTR
>> -DDISABLE_CVSID -I/usr/include/freetype2 -Irenderers/agg/include
>> -I/home/gridusr/local/instantclient_11_2/sdk/include
>> -I/home/gridusr/local/instantclient_11_2/rdbms/demo
>> -I/home/gridusr/local/instantclient_11_2/rdbms/public -I/usr/include/libxml2
>> mapserv.c -o mapserv.o >/dev/null 2>&1
>> /bin/sh ./libtool --mode=link --tag=CXX g++ -release 6.1-dev -rpath
>> /home/gridusr/local/lib renderers/agg/src/clipper.lo
>> renderers/agg/src/agg_arc.lo renderers/agg/src/agg_curves.lo
>> renderers/agg/src/agg_vcgen_contour.lo renderers/agg/src/agg_vcgen_dash.lo
>> renderers/agg/src/agg_vcgen_stroke.lo renderers/agg/src/agg_image_filters.lo
>> renderers/agg/src/agg_line_aa_basics.lo
>> renderers/agg/src/agg_line_profile_aa.lo
>> renderers/agg/src/agg_sqrt_tables.lo
>> renderers/agg/src/agg_embedded_raster_fonts.lo
>> renderers/agg/src/agg_trans_affine.lo
>> renderers/agg/src/agg_vpgen_clip_polygon.lo
>> renderers/agg/src/agg_vpgen_clip_polyline.lo
>> renderers/agg/src/agg_font_freetype.lo mapgeomutil.lo mapdummyrenderer.lo
>> mapogl.lo mapoglrenderer.lo mapoglcontext.lo mapimageio.lo mapcairo.lo
>> maprendering.lo mapgeomtransform.lo mapquantization.lo maptemplate.lo
>> mapbits.lo maphash.lo mapshape.lo mapxbase.lo mapparser.lo maplexer.lo
>> maptree.lo mapsearch.lo mapstring.lo mapsymbol.lo mapfile.lo maplegend.lo
>> maputil.lo mapscale.lo mapquery.lo maplabel.lo maperror.lo mapprimitive.lo
>> mapproject.lo mapraster.lo mapsde.lo mapogr.lo mappostgis.lo maplayer.lo
>> mapresample.lo mapwms.lo mapwmslayer.lo maporaclespatial.lo mapgml.lo
>> mapprojhack.lo mapthread.lo mapdraw.lo mapgd.lo mapagg.lo mapoutput.lo
>> mapgdal.lo mapimagemap.lo mapows.lo mapwfs.lo mapwfs11.lo mapwfslayer.lo
>> mapcontext.lo maphttp.lo mapdrawgdal.lo mapjoin.lo mapgraticule.lo
>> mapcopy.lo mapogcfilter.lo mapogcsld.lo maptime.lo mapwcs.lo mapwcs11.lo
>> mapcpl.lo cgiutil.lo maprasterquery.lo mapobject.lo mapgeos.lo
>> classobject.lo layerobject.lo mapio.lo mappool.lo mapregex.lo
>> mappluginlayer.lo mapogcsos.lo mappostgresql.lo mapcrypto.lo mapowscommon.lo
>> maplibxml2.lo mapdebug.lo mapchart.lo maptclutf.lo mapxml.lo mapkml.lo
>> mapkmlrenderer.lo mapogroutput.lo mapwcs20.lo  mapogcfiltercommon.lo
>> mapunion.lo mapcluster.lo mapxmp.lo mapuvraster.lo mapservutil.lo maptile.lo
>> -lfreetype -lgd -lgd -ljpeg -lfreetype -lpng -lz -lXpm -lX11    -lproj
>> -ljpeg -lpng -lgif  -L/home/gridusr/local/lib -lgdal   -lcurl
>> -L/home/gridusr/local/instantclient_11_2 -lclntsh  -lpthread -L -lc     -lz
>> -lxml2 -lz -lm  -lm -lstdc++      -o libmapserver.la
