[mapserver-dev] - How to compile 6.2
Alan Boudreault aboudreault at mapgears.com
Mon Jan 16 20:50:10 EST 2012
It is new in trunk... you have to specify the path to php-config rather
than the install path.
Alan
On 12-01-16 02:18 PM, scott159 at free.fr wrote:
> Ok but there is a problem when I compile mapserver with flag --with-php=/usr
> ----- Mail original -----
> De: "Stephan Meißl"<stephan at meissl.name>
> À: "Fabian Schindler"<fabian.schindler at eox.at>
> Cc: "mapserver-dev"<mapserver-dev at lists.osgeo.org>
> Envoyé: Dimanche 15 Janvier 2012 18:31:30
> Objet: Re: [mapserver-dev] - How to compile 6.2
> Don't forget to run make install which is mandatory now.
> Citing Thomas:
> building steps:
> ./configure [previous opts] --prefix=/usr/local
> make
> sudo make install
> cp /usr/local/bin/mapserv [cgi-bin-directory] #do *not* directly copy
> the mapserv binary from our top-level source directory, as it is a
> wrapper script and not compiled machine code.
> There are switches to compile Python and PHP MapScript in the steps
> above if needed.
> cu
> Stephan
> On Sun, 2012-01-15 at 13:37 +0100, Fabian Schindler wrote:
>> You probably have to refresh your Makefile. Try it with:
>> make clean
>> make distclean
>> Now you have to rerun ./configure using the '--with...' switches you
>> require.
>> Now you should be able to run 'make' again.
>> HTH
>> scott159 at free.fr schrieb:
>>          Hi,
>>          I try to compile mapserver 6.2 but it's seems that only "make" doesn't enought. I compile library GD, GDAL ... but I have errors when I launch "make" from mapserver 6.2. May be errors come from libtool ? I don't know ...
>>          What's command lines are necessary to try mapserver 6.2 dev ?
>>          Thanks
>>          scott
>>          ______________________________________________________________
>>          mapserver-dev mailing list
>>          http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Alan Boudreault
http://www.mapgears.com/
