[mapserver-dev] python mapscript and msCleanup issues
Umberto Nicoletti
umberto.nicoletti at gmail.com
Sun Jul 1 03:06:46 PDT 2012
Before we turn on debugging mode let's try a couple of simple changes to
your script:
http://pastebin.ca/2165984
I have replaced the call to msCleanup with a call to msIO_resetHandlers
which clears all buffers.
http://pastebin.ca/2165986
same as before but with the buffer accessed as a string rather than a byte
array (string is not copied inside mapscript, array is).
Let us now how this goes.
Umberto
On Thu, Jun 28, 2012 at 8:02 PM, Stephan Meißl <stephan at meissl.name> wrote:
> Thomas, Umberto,
> we created a simple (at least as simple as possible) test case. Here is
> a basic Python script: http://pastebin.ca/2165345 which we deployed in
> Apache using mod_wsgi with this config: http://pastebin.ca/2165346
> There is also a basic mapfile using the "road" data in "msautotets/wxs"
> http://pastebin.ca/2165329 but I suspect you can use whatever mapfile
> you have at hand.
> When we issue multiple simultaneous requests e.g. using this script
> http://pastebin.ca/2165348 (note the "&" at the end of the curl call)
> some of the requests result in errors.
> Either removing the call to msCleanup() or extending the Apache config
> to limit the number of threads to 1 (http://pastebin.ca/2165347) seems
> to resolve the issues but of course with limitations.
> Are we missing anything essential? How should we free request/map
> objects without using msCleanup() in Python?
> Thanks for any hint,
> Stephan
> On Thu, 2012-06-28 at 14:15 +0200, Umberto Nicoletti wrote:
> > Fabian,
> > if you could put together a test case that I can run to reproduce the
> > problem I will take a look into it.
> > Regards,
> > Umberto
> > On Thu, Jun 28, 2012 at 1:44 PM, thomas bonfort
> > <thomas.bonfort at gmail.com> wrote:
> > Fabian,
> > can you get a backtrace of the segfaults?
> > Aside from that, I would personally refrain from using threads
> > with
> > mapscript and stick to a prefork mpm in apache to accomplish
> > this. It
> > is also my understanding that calling msCleanup() should be
> > limited to
> > when a process is actually exiting, and not at the end of each
> > request, i.e. if I were you I would investigate where memory
> > is
> > leaking when freeing your request/map objects.
> > regards,
> > thomas
> > On Thu, Jun 28, 2012 at 11:28 AM, Fabian Schindler
> > <fabian.schindler at eox.at> wrote:
> > > Hi all,
> > > Has anyone had issues with Python MapScript and the
> > msCleanup() in
> > > WSGI-Apache applications? Using msCleanup() results in
> > strange
> > > errors/segfaults in multi-threaded setups but not using it
> > quickly eats up
> > > memory.
> > > We are developing a Django application to serve enhanced WCS
> > responses
> > > (according to the EO-WCS extension). For this purpose, we
> > use MapScript to
> > > receive a basic WCS response, which we are extending with
> > additional
> > > metadata.
> > > Our mapserver dispatch code is like this:
> > > mapscript.msIO_installStdoutToBuffer()
> > > dispatch_status = map.OWSDispatch(ows_req)
> > > content_type = mapscript.msIO_stripStdoutBufferContentType()
> > > mapscript.msIO_stripStdoutBufferContentHeaders()
> > > result = mapscript.msIO_getStdoutBufferBytes()
> > > mapscript.msCleanup(1)
> > > return result, content_type, dispatch_status
> > > Unfortunately we experienced several weird errors
> > (segfaults, hit assertions
> > > within GEOS, etc) when dispatching requests, especially in
> > multi-threaded
> > > environments (such as a deployment with Apache). We traced
> > this down and
> > > found that a call to `msCleanup` right after the OWSDispatch
> > was causing the
> > > problems.
> > > Taken from the mapscript documentation:
> > > "msCleanup() attempts to recover all dynamically allocated
> > resources
> > > allocated by MapServer code and dependent libraries. It it
> > used primarily
> > > for final cleanup in scripts that need to do memory leak
> > testing to get rid
> > > of “noise” one-time allocations. It should not normally be
> > used by
> > > production code."
> > > When we remove the call to msCleanup, no segfaults and other
> > errors occur
> > > within Apache. Unfortunately, while running our test cases
> > (including
> > > several hundreds MapServer dispatches) we quickly run out of
> > memory (e.g:
> > > memory consumption after 30 test cases was over 2.2 GiB
> > instead of about 150
> > > MB).
> > > Any ideas are welcome :)
> > > Thanks,
> > > Fabian
> > > _______________________________________________
> > > mapserver-dev mailing list
> > > mapserver-dev at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120701/03d8c4d9/attachment.html>
