[mapserver-dev] Buffer overflow in msOWSParseRequestMetadata
Fabian Schindler fabian.schindler at eox.at
Tue Jul 17 06:00:36 PDT 2012
Thomas,
Agreed. Let me know if I can help somewhere!
Fabian
On 07/17/2012 02:38 PM, thomas bonfort wrote:
> ok, I'm taking back my offer, I can't for the life of me figure out
> what the code is doing to try to replicate it differently in a manner
> that would be compatible with a release branch. For 6.0 I'd just
> augment the buffer size as you did to correct your issue. For 6.2 the
> area would need some refactoring to at least address these issues:
> - int msOWSRequestIsEnabled(mapObj *map, layerObj *layer, const char
> *namespaces, const char *request, int check_all_layers) is always
> called with layer=NULL and check_all_layers=true
> - int msOWSParseRequestMetadata(const char *metadata, const char
> *request, int *disabled) has the fixed buffer issue you mentionned,
> and will set *disabled to true even if the request is explicitely
> enabled
> - void msOWSRequestLayersEnabled(mapObj *map, const char *namespaces,
> const char *request, owsRequestObj *ows_request) is malloc'ing but not
> initializing ows_request->enabled_layers which is suspicious.
>  From my limited understanding of this area of the code, I would
> suggest modifying msOWSParseRequestMetadata to int
> msOWSParseRequestMetadata(const char *metadata, const char *request),
> returning either MS_TRUE, MS_FALSE or MS_UNKNOWN and let the higher
> level code make a decision based on that answer.
> thomas
> On Tue, Jul 17, 2012 at 1:06 PM, Fabian Schindler
> <fabian.schindler at eox.at>  wrote:
>> Thomas,
>> PS: can you open an issue for this ?
>> Done: https://github.com/mapserver/mapserver/issues/4393
>> Augmenting the buffer size isn't an appropriate fix imho. We can have
>> two different fixes:
>> - char requestBuffer = msSmallMalloc(strlen(metadata)+1); instead of
>> char requestBuffer[32]; This has the inconvenience of calling a
>> malloc.
>> The function is actually called quite often, and using dynamic memory
>> allocation may result in a worse performance.
>> - The code there seems quite complicated, and if I understand
>> correctly what it's trying to do can be replaced with some calls to
>> strcasestr. As Alan is absent this week, I'd be willing to implement
>> and apply a patch provided you can help validate it doesn't have
>> side-effects I did not foresee?
>> That would be great! I'm willing to help on the validation and testing.
>> As for 6.0.4 there are no immediate plans I think. Can you package
>> 6.0.3 + a patch for the liveDVD?
>> Actually we use the pre-installed version of MapServer on the liveDVD, I'm
>> not yet sure how we can solve the issue for us. Perfect would be a 6.0.4
>> release on UbuntuGIS, but I'm afraid that won't happen in time :)
>> Thanks a lot,
>> Fabian
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
