[mapserver-dev] GetStyles SLD does not include LAYER's Opacity value
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Thu Jun 7 13:32:29 PDT 2012
Your logic seems reasonable but I'm guessing there's a reason layer->opacity is not leveraged. I'm wondering if Assefa is still around to explain why things are as they are. Go ahead and file a ticket.
Steve
-----Original Message-----
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of myOpenLayersUName
Sent: Wednesday, June 06, 2012 12:30 PM
To: mapserver-dev at lists.osgeo.org
Subject: [mapserver-dev] GetStyles SLD does not include LAYER's Opacity value
I originally created a post about this in the Users forum (http://osgeo-org.1560.n6.nabble.com/GetStyles-SLD-does-not-include-Opacity-value-td4979066.html#a4979520),
but after learning more about it I believe it's more appropriately included in the Dev forum. If I have erred in doing so, I apologize.
To summarize, in 6.0.1 (and 6.0.3 according to the source), I have a Map file with a LAYER OPACITY value set to 20. When I perform a GetStyles request the Rule in the response does not include a "fill-opacity"
CssParameter. Steve Lime suggested that I could deal with this by moving the OPACITY setting to the LAYER's CLASS' STYLE block and he was correct. Doing so, in my simple LAYER, returned the fill-opacity in the GetStyles request.
After having thought more about this though, I think there is still a problem. Whereas my example only has a single CLASS, often there are multiple and having to introduce the same OPACITY to all those CLASS definitions just increases the risk of things getting inconsistent along the way.
In creating the GetStyles response, the code should look at the CLASS STYLE`s OPACITY definition but also at the LAYER`s OPACITY definition to determine whether the fill-opacity should be added to the Rule. Certainly, a GetMap or GetLegendGraphic request knows to accommodate the definition occurring in either place (although I had not expected the LAYER's OPACITY definition to override the CLASS STYLE's definition; I expected the opposite but it's consistent so not important).
I believe, therefore that the code in mapogcsld.c's msSLDGeneratePolygonSLD should read something like this (in the section where it's dealing with the
fill-opacity):
if(psLayer->opacity != 100 && psLayer->opacity != -1) {
snprintf(szTmp, sizeof(szTmp),
"<%s name=\"fill-opacity\">%.2f</%s>\n",
sCssParam, (float)psLayer->opacity/100, sCssParam);
pszSLD = msStringConcatenate(pszSLD, szTmp);
else if(psStyle->color.alpha != 255 && psStyle->color.alpha!=-1) {
sCssParam, (float)psStyle->color.alpha/255, sCssParam);
(NOTE: stroke-opacity would be similar but isn't covered in the polygon or line symbolizers at all at the moment).
Can someone verify if I am correct in my assumptions with this and, if so, I'll create a ticket to request it be added to the Mapserver code.
Cheers,
jtm
View this message in context: http://osgeo-org.1560.n6.nabble.com/GetStyles-SLD-does-not-include-LAYER-s-Opacity-value-tp4979569.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
mapserver-dev mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
