[mapserver-dev] [motion] code formatting and astyle
Olivier Courtin
olivier.courtin at oslandia.com
Tue Jun 26 09:38:22 PDT 2012
On Jun 26, 2012, at 4:27 PM, Daniel Morissette wrote:
> On 12-06-26 9:42 AM, thomas bonfort wrote:
>> I have an "astyle" branch, for mapogr.cpp, you can have a look at
>> https://github.com/tbonfort/mapserver/blob/658a5cd39e6680dd5a752b9b741da52b276c5c57/mapogr.cpp
> I reviewed the result with Thomas on IRC, and we found an oddity with the switch/case statements where the "case ..:" header was not indented. So in the end we ended up using the following options which seem to give acceptable result relatively close to SteveL's original style:
> astyle -—style=kr -—indent-switches -—indent=spaces=2 --lineend=linux --convert-tabs
> Based on a quick review of mapogr.cpp with that style I am ready to +1 the motion using the options above.
+1
Olivier
