[mapserver-dev] Build issues with current git master
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Jun 26 15:59:56 PDT 2012
Hi Angelos,
You mentioned that you have no troubles building PHP mapscript with
git-master, can you confirm this for me again? I seem to get the following
errors today on Windows:
Creating library php_mapscript.lib and object php_mapscript.exp
php_mapscript_util.obj : error LNK2019: unresolved external symbol
_mapscript_create_label
leader referenced in function _mapscript_fetch_object
php_mapscript_util.obj : error LNK2001: unresolved external symbol
_mapscript_ce_labellead
er
label.obj : error LNK2001: unresolved external symbol
_mapscript_ce_labelleader
class.obj : error LNK2001: unresolved external symbol
php_mapscript.obj : error LNK2019: unresolved external symbol
_zm_startup_labelleader refe
renced in function _zm_startup_mapscript
mapscript_i.obj : error LNK2019: unresolved external symbol _msCopyLine
referenced in func
tion _lineObj_clone
_msCopyProjection referenced i
n function _projectionObj_clone
php_mapscript.dll : fatal error LNK1120: 5 unresolved externals
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
9.0\VC\BIN\link.EXE"
' : return code '0x460'
Stop.
9.0\VC\BIN\nmake.EXE
"' : return code '0x2'
Stop.
-jeff
View this message in context: http://osgeo-org.1560.n6.nabble.com/Build-issues-with-current-git-master-tp4983668p4984085.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
