[mapserver-dev] python mapscript and msCleanup issues
Fabian Schindler
fabian.schindler at eox.at
Thu Jun 28 02:28:35 PDT 2012
Hi all,
Has anyone had issues with Python MapScript and the msCleanup() in
WSGI-Apache applications? Using msCleanup() results in strange
errors/segfaults in multi-threaded setups but not using it quickly eats
up memory.
We are developing a Django application to serve enhanced WCS responses
(according to the EO-WCS extension). For this purpose, we use MapScript
to receive a basic WCS response, which we are extending with additional
metadata.
Our mapserver dispatch code is like this:
mapscript.msIO_installStdoutToBuffer()
dispatch_status = map.OWSDispatch(ows_req)
content_type = mapscript.msIO_stripStdoutBufferContentType()
mapscript.msIO_stripStdoutBufferContentHeaders()
result = mapscript.msIO_getStdoutBufferBytes()
mapscript.msCleanup(1)
return result, content_type, dispatch_status
Unfortunately we experienced several weird errors (segfaults, hit
assertions within GEOS, etc) when dispatching requests, especially in
multi-threaded environments (such as a deployment with Apache). We
traced this down and found that a call to `msCleanup` right after the
OWSDispatch was causing the problems.
Taken from the mapscript documentation:
"msCleanup() attempts to recover all dynamically allocated resources
allocated by MapServer code and dependent libraries. It it used
primarily for final cleanup in scripts that need to do memory leak
testing to get rid of “noise” one-time allocations. It should not
normally be used by production code."
When we remove the call to msCleanup, no segfaults and other errors
occur within Apache. Unfortunately, while running our test cases
(including several hundreds MapServer dispatches) we quickly run out of
memory (e.g: memory consumption after 30 test cases was over 2.2 GiB
instead of about 150 MB).
Any ideas are welcome :)
Thanks,
Fabian
