[mapserver-dev] grid and python mapscript - missing ?
Jachym Cepicky
jachym.cepicky at gmail.com
Fri Mar 2 16:26:08 EST 2012
Steve, it took me longer to test this issue, but finally, I did it:
grid = mapscript.layerObj(mapObj)
grid.updateFromString("""LAYER
NAME "grid"
TYPE LINE
STATUS ON
CLASS
COLOR 0 0 0
LABEL
COLOR 255 0 0
TYPE truetype
SIZE 8
POSITION AUTO
PARTIALS FALSE
BUFFER 5
OUTLINECOLOR 255 255 255
END
END
PROJECTION
"init=epsg:4326"
END
GRID
LABELFORMAT "DDMM"
MAXARCS 10
MAXINTERVAL 10
MAXSUBDIVIDE 2
END
END""")
result is
'Exception: msInitializeVirtualTable(): General error message. Unknown
connectiontype, it was -1\ngetSymbol(): Symbol definition error. Parsing
error near (GRATICULE):(line 143)\n'
If I comment out the "GRID" part, it works.
When I update the layer with the GRID part only, so basically:
grid.name = "grid"
grid.type = mapscript.MS_LAYER_LINE
grid.status = mapscript.MS_ON
cls = mapscript.classObj(grid)
sty = mapscript.styleObj(cls)
sty.color = mapscript.colorObj(0,100,100)
GRID
LABELFORMAT "DDMM"
MAXARCS 10
MAXINTERVAL 10
MAXSUBDIVIDE 2
END""")
result is the same :-(
Any hint how to approach furter?
Thanks a lot for your time!
Jachym
On 19.10.2011 20:39, Steve Lime wrote:
> Sorry for the delayed response, I didn't see any other responses...
> You're correct. I see in mapserver.h that the grid object is hidden
> from SWIG. I think that's because of the way a graticuleObj manifests
> itself in a layer. It's only there (via layer->layerinfo) if GRID is
> present at the time the mapfile is processed. Hmmm...
> I'm wondering then if you work through the
> layer->updateFromString(gridText) where gridText contains the
> appropriate mapfile snippet. Is that sufficient?
> There may be other alternatives such as exposing the graticuleObj to
> SWIG and then adding a method like layer->getGrid().
> Steve
> On Sat, Oct 8, 2011 at 4:12 AM, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
>> Hi,
>> is there a way, how to define GRID with help of Python mapscript? I have a
>> feeling, that it is missing in the swig interface.
>> Thanks
>> Jachym
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Desc: OpenPGP digital signature
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120302/343cd5b1/signature.bin
