[mapserver-dev] MS 6.0.2 bug
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Mar 3 20:05:02 EST 2012
Ok, I have found out how to work around the problem so this might help a
developer figure out why it is happening. I have a SYMBOLSET file with
the shield symbols defined as follows. I will also note that is does not
occur at all zoom levels within the LAYERs scale range. Maybe the symbol
is getting bumped out in the drawLabelCache so it doesn't get executed.
-Steve W
SYMBOL
NAME "I"
TYPE PIXMAP
IMAGE "icons2/hwy/interstate.png"
TRANSPARENT 7
END
SYMBOL
NAME "U"
TYPE PIXMAP
IMAGE "icons2/hwy/ushwy.png"
TRANSPARENT 1
END
SYMBOL
NAME "S"
TYPE PIXMAP
IMAGE "icons2/hwy/sthwy.png"
END
My layer definition is this:
LAYER
NAME "hwyshieldsnear"
METADATA
"ows_title" "Hwy Shields Near"
"ows_srs" "EPSG:4269 EPSG:4326"
"ows_abstract" "Hwy Shields for the U.S. Census ROADS data
layer."
END
TYPE ANNOTATION
TILEINDEX "tidx-ROADS"
PROJECTION
"+proj=longlat +ellps=GRS80 +datum=NAD83" #EPSG: 4269
END
MAXSCALEDENOM 300000
FILTER (length('[RTENUM]')>0 && '[RTTYP]' ~ '^(I|U|S)$')
CLASSITEM "RTTYP"
LABELITEM "RTENUM"
CLASS
EXPRESSION "I"
STYLE
# SYMBOL [RTTYP] ##### This cause the error #########
SYMBOL "I" ##### This works fine #########
END
LABEL
SIZE TINY
POSITION CC
OFFSET 1 0
MINDISTANCE 100
COLOR "#ffffff"
PARTIALS FALSE
PRIORITY 7
END
END
CLASS
EXPRESSION "U"
STYLE
SYMBOL "U"
END
LABEL
SIZE TINY
POSITION CC
OFFSET 1 0
MINDISTANCE 100
COLOR "#000000"
PARTIALS FALSE
PRIORITY 7
END
END
CLASS
EXPRESSION "S"
STYLE
SYMBOL "circle-filled"
COLOR "#FFFFFF"
OUTLINECOLOR "#000000"
SIZE 19
END
LABEL
SIZE TINY
POSITION CC
MINDISTANCE 100
COLOR "#000000"
PARTIALS FALSE
PRIORITY 7
END
END
END
On 3/3/2012 7:10 PM, Stephen Woodbridge wrote:
> Here is a valgrind report that should a couple of leaks but doesn't shed
> any light on error below and one error that may/may not be related to it:
> woodbri at mappy:/u/software/mapserver-6.0.2$ valgrind --leak-check=full
> ./mapserv
> QUERY_STRING='MAP=%2Fu%2Fdata%2Ftgr2011-maps%2Ftiger2011-tmp.map&FORMAT=image%2Fpng&MAP_IMAGETYPE=agg_qn&LAYERS=Tiger_2011&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=-9803618.4071426,5152908.7732279,-9800274.287239,5155536.2960093&WIDTH=700&HEIGHT=550'
> ==21971== Memcheck, a memory error detector.
> ==21971== Copyright (C) 2002-2007, and GNU GPL'd, by Julian Seward et al.
> ==21971== Using LibVEX rev 1854, a library for dynamic binary translation.
> ==21971== Copyright (C) 2004-2007, and GNU GPL'd, by OpenWorks LLP.
> ==21971== Using valgrind-3.3.1-Debian, a dynamic binary instrumentation
> framework.
> ==21971== Copyright (C) 2000-2007, and GNU GPL'd, by Julian Seward et al.
> ==21971== For more details, rerun with: -v
> ==21971==
> [Sat Mar 3 19:07:01 2012].499464 msDrawMap(): rendering using
> outputformat named agg_qn (AGG/PNG).
> [Sat Mar 3 19:07:01 2012].583443 msDrawMap(): WMS/WFS set-up and query,
> 0.015s
> [Sat Mar 3 19:07:10 2012].476239 msDrawMap(): Layer 2 (World Z2), 8.864s
> [Sat Mar 3 19:07:10 2012].532026 msDrawMap(): Layer 3 (Forest), 0.050s
> [Sat Mar 3 19:07:10 2012].838982 msDrawMap(): Layer 6 (Lakes Z2), 0.306s
> [Sat Mar 3 19:07:11 2012].126799 msDrawMap(): Layer 7 (World Boundaries
> Z1), 0.285s
> [Sat Mar 3 19:07:13 2012].548199 msDrawMap(): Layer 16 (state), 2.421s
> [Sat Mar 3 19:07:14 2012].23603 msDrawMap(): Layer 19 (place), 0.475s
> [Sat Mar 3 19:07:14 2012].575893 msDrawMap(): Layer 20 (area_landmarks),
> 0.552s
> [Sat Mar 3 19:07:14 2012].609551 msDrawMap(): Layer 21 (military), 0.033s
> [Sat Mar 3 19:07:15 2012].994444 msDrawMap(): Layer 22 (area_water), 1.385s
> [Sat Mar 3 19:07:16 2012].68264 msDrawMap(): Layer 23 (linear_water),
> 0.073s
> [Sat Mar 3 19:07:16 2012].133183 msDrawMap(): Layer 26 (rails), 0.064s
> [Sat Mar 3 19:07:17 2012].222080 msDrawMap(): Layer 27 (roads), 1.088s
> [Sat Mar 3 19:07:17 2012].371530 msDrawMap(): Layer 28
> (point_landmarks), 0.149s
> [Sat Mar 3 19:07:17 2012].583520 msDrawMap(): Layer 30 (hwyshieldsnear),
> 0.212s
> [Sat Mar 3 19:07:17 2012].586644 msDrawLabelCache():
> labelcache_map_edge_buffer = 10
> [Sat Mar 3 19:07:18 2012].301754 msGetMArkerSize(): General error
> message. msGetMarkerSize() called on unloaded pixmap symbol, this is a
> bug in mapserver itself
> ==21971== Conditional jump or move depends on uninitialised value(s)
> ==21971== at 0x4E2026: agg2RenderBitmapGlyphs(imageObj*, double, double,
> labelStyleObj*, char*) (in /u/software/mapserver-6.0.2/mapserv)
> ==21971== by 0x44A3A0: msWriteErrorImage (in
> ==21971== by 0x4CD857: msWMSException (in
> ==21971== by 0x4D57F7: msWMSDispatch (in
> ==21971== by 0x470829: msOWSDispatch (in
> ==21971== by 0x4157DC: main (in /u/software/mapserver-6.0.2/mapserv)
> [Sat Mar 3 19:07:18 2012].929013 msFreeMap(): freeing map at 0x10a1a960.
> ==21971==
> ==21971== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 10 from 1)
> ==21971== malloc/free: in use at exit: 217 bytes in 80 blocks.
> ==21971== malloc/free: 19,643 allocs, 19,563 frees, 26,189,909 bytes
> allocated.
> ==21971== For counts of detected errors, rerun with: -v
> ==21971== searching for pointers to 80 not-freed blocks.
> ==21971== checked 4,336,552 bytes.
> ==21971==
> ==21971==
> ==21971== 90 bytes in 79 blocks are definitely lost in loss record 1 of 2
> ==21971== at 0x4C2260E: malloc (vg_replace_malloc.c:207)
> ==21971== by 0x85CDDF1: strdup (in /lib/libc-2.7.so)
> ==21971== by 0x425FD9: msStrdup (in /u/software/mapserver-6.0.2/mapserv)
> ==21971== by 0x4688F4: msSelectOutputFormat (in
> ==21971== by 0x468987: msPostMapParseOutputFormatSetup (in
> ==21971== by 0x438E54: loadMapInternal (in
> ==21971== by 0x43A3F7: msLoadMap (in /u/software/mapserver-6.0.2/mapserv)
> ==21971== by 0x414FD8: loadMap (in /u/software/mapserver-6.0.2/mapserv)
> ==21971== by 0x415138: main (in /u/software/mapserver-6.0.2/mapserv)
> ==21971==
> ==21971==
> ==21971== 127 bytes in 1 blocks are definitely lost in loss record 2 of 2
> ==21971== by 0x427B60: msEncodeHTMLEntities (in
> ==21971== by 0x4CD7FD: msWMSException (in
> ==21971==
> ==21971== LEAK SUMMARY:
> ==21971== definitely lost: 217 bytes in 80 blocks.
> ==21971== possibly lost: 0 bytes in 0 blocks.
> ==21971== still reachable: 0 bytes in 0 blocks.
> ==21971== suppressed: 0 bytes in 0 blocks.
> On 3/3/2012 6:07 PM, Stephen Woodbridge wrote:
>> I just got a weird error message:
>> msGetmarkerSize(): General error message. msGetMarkerSize() called on
>> unloaded pixmap symbol, this is a bug in mapserver itself
>> Any idea what this is and how come we do not trap this condition and
>> handle it in a benign way? Is this caused by having too many symbols
>> defined?
>> This is easy for me to reproduce with this mapfile.
>> -Steve W.
>> Here is the error log:
>> [Sat Mar 03 15:37:20 2012] [error] [client 108.20.60.11] [Sat Mar 3
>> 15:37:20 2012].720259 msDrawMap(): rendering using outputformat named
>> agg_qn (AGG/PNG)., referer:
>> http://imaptools.com:8080/demo/tiger2011.html?zoom=14&lat=41.88389&lon=-88.04234&layers=B0
>> 15:37:20 2012].720475 msDrawMap(): WMS/WFS set-up and query, 0.000s,
>> referer:
>> 15:37:20 2012].866600 msDrawMap(): Layer 2 (World Z2), 0.146s, referer:
>> 15:37:20 2012].867559 msDrawMap(): Layer 3 (Forest), 0.001s, referer:
>> 15:37:20 2012].872924 msDrawMap(): Layer 6 (Lakes Z2), 0.005s, referer:
>> 15:37:20 2012].874245 msDrawMap(): Layer 7 (World Boundaries Z1),
>> 0.001s, referer:
>> 15:37:20 2012].916075 msDrawMap(): Layer 16 (state), 0.042s, referer:
>> 15:37:20 2012].926136 msDrawMap(): Layer 19 (place), 0.010s, referer:
>> 15:37:20 2012].928578 msDrawMap(): Layer 20 (area_landmarks), 0.002s,
>> referer:
>> 15:37:20 2012].929427 msDrawMap(): Layer 21 (military), 0.001s, referer:
>> 15:37:20 2012].955001 msDrawMap(): Layer 22 (area_water), 0.026s,
>> referer:
>> 15:37:20 2012].956590 msDrawMap(): Layer 23 (linear_water), 0.002s,
>> referer:
>> 15:37:20 2012].958226 msDrawMap(): Layer 26 (rails), 0.002s, referer:
>> 15:37:20 2012].992081 msDrawMap(): Layer 27 (roads), 0.034s, referer:
>> 15:37:20 2012].993642 msDrawMap(): Layer 28 (point_landmarks), 0.001s,
>> referer:
>> 15:37:20 2012].998422 msDrawMap(): Layer 30 (hwyshieldsnear), 0.005s,
>> referer:
>> 15:37:20 2012].998479 msDrawLabelCache(): labelcache_map_edge_buffer =
>> 10, referer:
>> [Sat Mar 03 15:37:21 2012] [error] [client 108.20.60.11] [Sat Mar 3
>> 15:37:21 2012].16760 msGetMArkerSize(): General error message.
>> msGetMarkerSize() called on unloaded pixmap symbol, this is a bug in
>> mapserver itself, referer:
>> 15:37:21 2012].44957 msFreeMap(): freeing map at 0x20eeb20., referer:
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
