[mapserver-dev] Potential GSoC idea was: (Fwd: Re:
[mapserver-users] force labels to fit in polygons)
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Mar 5 17:31:36 EST 2012
An interesting potential GSoC project might be something along the line
of offline label placement optimization. An idea would be to take a
mapfile and zoom scale then compute the potential label points, bboxs,
placement options and analyze them for optimal placement and then to
create a label layer for that scale. To make the task scalable, it could
be done in tiles.
Anyway, there are probably plenty of scholarly papers on the subject.
https://www.google.com/#q=optimal+label+placement+maps
So my thought is that while the problem is NP hard like TSP, that there
are good general solutions to TSP that do not provide the best result
but are provide good results in fast times. One of these algorithms is
simulated annealing. This works by taking a initial solution, then
looking for collisions and changing the label point associated with the
colliding labels. It them scores the solution, makes some random changes
cleans up the collisions again and compares the new score to the
previous iteration and if it is better keeps it, and repeats if it is
worse it resets back to the better solution and does another iteration.
It does this for some N iterations or until it can not improve on the
solution.
Interestingly, this [1] paper discusses simulated annealing as part of a
solution.
Regardless, something like this might be an interesting GSoC project. It
might be fast enough to run in mapserver may as part of mapcache when
rendering tiles.
Just an idea,
-Steve
[1] http://www.eecs.harvard.edu/shieber/Biblio/Papers/tog-final.pdf
-------- Original Message --------
Subject: Re: [mapserver-users] force labels to fit in polygons
Date: Mon, 05 Mar 2012 16:50:42 -0500
From: Stephen Woodbridge <woodbri at swoodbridge.com>
To: mapserver-users at lists.osgeo.org
On 3/5/2012 4:44 PM, Mark Volz wrote:
> Hello,
> Is there a way to force labels to fit inside of a polygon, even if a
> polygon is irregularly shaped? I noticed that with POSITION AUTO labels
> are falling outside of my soils boundary.
The short answer is no. It is an interesting problem, but it does not
have a guaranteed result as the label might be too big to fit
regardless. I am not even sure of the algorithm should be for something
like this. There are a lot of parameters like:
font
font size
wrapping the text
changing the angle
finding the longest line, arc or smooth polyline that fits withing the
polygon and then have the text follow that line
These are all computationally expensive to do on the fly while
rendering. Ideally these should be worked out in advance then you can
supply the attributes to the label via binding columns in the data.
-SteveW
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
