[mapserver-dev] WMS 1.3 GetFeatureInfo troubles with spatialite
Fabian Schindler
fabian.schindler at eox.at
Tue Mar 6 11:55:55 EST 2012
Hi List,
I'm having some troubles getting a GetFeatureRequest running with a
spatialite DB. It works on a PostGIS backend, but with spatialite I only
get empty result sets. (Not even the header and footer html templates
are returned).
I'm using a Python MapScript application where I dynamically create a
layer, but I managed to reproduce the scenario with a static mapfile[1].
With the request
mapserv -nv
QUERY_STRING="map=template.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetFeatureInfo&LAYERS=test&QUERY_LAYERS=test&STYLES=&BBOX=32.158895,-3.75,46.3,28.326165&FEATURE_COUNT=10&HEIGHT=100&WIDTH=200&FORMAT=image%2Fpng&INFO_FORMAT=text/html&CRS=EPSG:4326&I=100&J=50"
I receive the following debug output [2] and an empty HTTP response [3].
With the request:
mapserv -nv
QUERY_STRING="map=template.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&LAYERS=test&QUERY_LAYERS=test&STYLES=&BBOX=32.158895,-3.75,46.3,28.326165&FEATURE_COUNT=10&HEIGHT=100&WIDTH=200&FORMAT=image%2Fpng&INFO_FORMAT=text/html&CRS=EPSG:4326&I=100&J=50"
I'm able to produce a nice image of the polygons within the sqlite file.
Any hints for me?
Thanks,
Fabian
[1]:
MAP
CONFIG "MS_ERRORFILE" "stderr"
DEBUG 5
WEB
METADATA
"ows_enable_request" "*"
"ows_feature_info_mime_type" "text/html text/xml"
"wms_include_items" "text/html text/xml"
END
END
PROJECTION
"+init=epsg:4326"
END
LAYER
DEBUG 5
STATUS on
DUMP true
TYPE polygon
NAME test
DATA "SELECT eomd.id AS oid, eomd.footprint AS geometry,
cov.coverage_id FROM coverages_eometadatarecord AS eomd,
coverages_coveragerecord AS cov, coverages_rectifieddatasetrecord AS
rectd, coverages_datasetseriesrecord_rect_datasets AS ds2rectd WHERE
ds2rectd.datasetseriesrecord_id = 9 AND
ds2rectd.rectifieddatasetrecord_id = rectd.coveragerecord_ptr_id AND
cov.resource_ptr_id = rectd.coveragerecord_ptr_id AND
rectd.eo_metadata_id = eomd.id UNION SELECT eomd.id AS oid,
eomd.footprint AS geometry, cov.coverage_id FROM
coverages_eometadatarecord AS eomd, coverages_coveragerecord AS cov,
coverages_referenceabledatasetrecord AS refd,
coverages_datasetseriesrecord_ref_datasets AS ds2refd WHERE
ds2refd.datasetseriesrecord_id = 9 AND
ds2refd.referenceabledatasetrecord_id = refd.coveragerecord_ptr_id AND
cov.resource_ptr_id = refd.coveragerecord_ptr_id AND refd.eo_metadata_id
= eomd.id"
CONNECTION "config.sqlite"
CONNECTIONTYPE ogr
PROJECTION
"+init=epsg:4326"
END
METADATA
"wms_srs" "EPSG:4326"
"wms_label" "test"
END
TEMPLATE "outline_template_dataset.html"
HEADER "outline_template_header.html"
FOOTER "outline_template_footer.html"
CLASS
STYLE
OUTLINECOLOR 255 0 0
END
NAME red
END
CLASSGROUP red
END
END # MAP
[2]
CGI Request 1 on process 14758
msWMSLoadGetMapParams(): enabling non-square pixels.
msOGRFileOpen(config.sqlite)...
OGROPen(/home/fabian/workspace/test/./config.sqlite)
msConnPoolRegister(test,config.sqlite,0x86cb50)
msProjectRect(): some points failed to reproject, doing internal
sampling.
msOGRFileWhichShapes: Setting spatial filter to 12.368273 39.158742
12.368273 39.158742
msOGRFileNextShape: Returning MS_DONE (no more shapes)
msOGRLayerClose(config.sqlite).
msOGRFileClose(/home/fabian/workspace/test/./config.sqlite,-1).
msConnPoolRelease(test,config.sqlite,0x86cb50)
msConnPoolClose(config.sqlite,0x86cb50)
msQueryByPoint(): Search returned no results. No matching record(s)
found.
mapserv request processing time (msLoadMap not incl.): 0.007s
msFreeMap(): freeing map at 0x85aee0.
freeLayer(): freeing layer at 0x8630c0.
[3]
Content-type: text/html
