[mapserver-dev] 6.0.3 (was: 6.2) release
    Tamas Szekeres
    szekerest at gmail.com
    Fri May 18 10:44:57 EDT 2012
+1
Tamas
2012/5/18 Daniel Morissette <dmorissette at mapgears.com>
> On 12-05-18 8:22 AM, Jeff McKenna wrote:
>> Is there any interest to push out a 6.0.3 release today, to coincide
>> with the GDAL 1.9.1 release?   I mean interest other than my own :)   My
>> thinking is that it would be good to do before the North American summer
>> holidays start.
> +1 since there seem to be a good set of changes in the GIT branch (see
> below).
> I guess I should take care of it as release manager of the 6.0 branch.
> I'll see if I can get to that today.
> Daniel
> Current Version (future 6.0.3, SVN branch-6-0):
> - Fix creation of a vector symbolObj in mapscript (#4318)
> - Added coverage metadata in WCS (#4306)
> - Adjusted WCS 2.0 GetCapbilities response (#4003)
> - Ignore unknown requets parameteres in WCS 2.0 (#4307).
> - Fixed mapscript is unusable in a web application due to memory leaks
> (#4262)
> - Fixed getFeature request with custom output format fails on filter
> encoding (#4190)
> - Fixed resolution when UoM changes in WCS 2.0 (#4283)
> - Added missing DEFRESOLUTION parameter to msCopyMap() function (#4272)
> - Fixed Python MapScript layerObj/classObj Error (#3940)
> - Fixed WCS 2.0 axis order, offset vector, and origin (#4006, #4191)
> - Fixed PHP MapScript opacity property of StyleObj no longer works (#3920)
> - Added MS_CJC_* constants in PHP/MapScript (#4183)
> - Fixed Memory leak with fribidi strings (#4188)
> - Added missing properties in styleObj setter of PHP/MapScript (#3901)
> ______________________________**_________________
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/mapserver-dev<http://lists.osgeo.org/mailman/listinfo/mapserver-dev>
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120518/6fcdc435/attachment.html
