[mapserver-dev] heads up on gd,png,gif and jpeg build changes
thomas bonfort thomas.bonfort at gmail.com
Tue May 29 07:47:22 PDT 2012
what ./configure args ?
On Tue, May 29, 2012 at 4:43 PM, Lime, Steve D (DNR)
<Steve.Lime at state.mn.us> wrote:
> Running into:
> checking for ft2build.h... yes
> ./configure: line 18354: syntax error near unexpected token `else'
> ./configure: line 18354: `else'
> I had done:
> rm configure
> git pull origin master
> autoconf
> ./configure ...
> Steve
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of thomas bonfort
> Sent: Monday, May 28, 2012 8:48 AM
> To: MapServer Dev Mailing List
> Subject: [mapserver-dev] heads up on gd,png,gif and jpeg build changes
> Hi devs,
> In order to resolve [1] and less importantly [2], I have made some non trivial changes to the logic used inside the configure script when looking for libpng, libjpeg, giflib and libgd. For the first three, we now try to link against the libraries instead of explicitely looking for libxxx.so in a set of predefined locations. For libgd, we now look for the gdlib-config utility.
> This might cause some minor issues with existing build scripts, which I hope I can quickly iron out if you report them here or in a new ticket.
> cheers,
> thomas
> [1] https://github.com/mapserver/mapserver/issues/4315
> [2] https://github.com/mapserver/mapserver/issues/386
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
