[mapserver-dev] Create a map form SHP file
Stephen Woodbridge woodbri at swoodbridge.com
Tue May 29 10:20:34 PDT 2012
On 5/29/2012 1:09 PM, Jualboma wrote:
> Hi everyone...
> I have a little problem, i´m new using the map-server library and i´m trying
> to devlopment a "visor" but i have a question. using that library is
> possible import a SHP file and show it using map-server?? i means, i want
> that one user can choose a compressed file (ZIP). This file (ZIP) can
> contain .shp, .dbf, .prj etc, etc. And having those files, using (if its
> possible) the map-server libraries could create a map with the layers that
> de SHP file have.
> I appreciate any help, books, link, any kind of references!!! Thks a
> lot...and sorry for my English!!!
No mapserver does not do this by itself. You might want to look into
writing a PHP script the handles uploading a zipped shapefile,
extracting it to a tmp directory and generating a simple mapefile based
on if it is a point, line, or polygon shapefile.
You should beware of security issues when uploading zip files that might
contain other not shapefile files that might try to overwrite other
files on your system or load malware.
-Steve W
