[mapserver-dev] (no subject)
李杨
gisyangli at gmail.com
Mon Nov 5 22:50:41 PST 2012
Or in another way to ask. I want to know the
mechanism<http://dict.cn/mechanism> of
it. Is that the mapserver first change the shp file to some type of image
format(such as bitmap), then change it to png? (in shp2img or other
related method ).
I recently do an application that need to change a GIS vector format file
to png file, and want to know should I first change to GIS vector file
first to some type raster format, then use libpng to saved as png format
and I think that maybe not a good method.
So I come here andI want to learn some process ways from mapserver , who
know the mechanism <http://dict.cn/mechanism> of mapserver processing like
in "shp2img" method.
thanks
2012/11/5 Lime, Steve D (DNR) <Steve.Lime at state.mn.us>
> It’s all over the place, I mean there are lots of moving pieces to what
> is seemingly a simple operation. You’ll need to be more specific. For the
> most part the source files are named somewhat intelligently…****
> Steve ****
> *From:* mapserver-dev-bounces at lists.osgeo.org [mailto:
> mapserver-dev-bounces at lists.osgeo.org] *On Behalf Of *??
> *Sent:* Monday, November 05, 2012 1:03 AM
> *To:* mapserver-dev at lists.osgeo.org
> *Subject:* [mapserver-dev] (no subject)****
> Hi,****
> everyone,****
> I now is learn how to generate png format file from shape or other gis
> data,****
> I use maperver and know use such as "shp2img -m osm-google.map -o output.png -map_debug 3"
> , just in mapfile configure a shapefile layer, then we can get the
> output.png.****
> My question is where to find the related code in mapserver src involving
> processing the shp data to png? ****
> thanks a lot.****
> Yang Li****
> GIS Developer****
> P.R.China****
Yang Li
GIS Developer
P.R.China
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20121106/f60849b8/attachment.html>
