[mapserver-dev] 6.2 release notes/announcement
thomas bonfort
thomas.bonfort at gmail.com
Tue Nov 13 09:02:36 PST 2012
On Tue, Nov 13, 2012 at 5:49 PM, Lime, Steve D (DNR) <Steve.Lime at state.mn.us
> wrote:
> At least for the few things I had a hand the doc look fine. There really
> is some great new stuff. Couple of comments:****
> **- **Maybe we should have an TOC at the top?
will do
> **- **I’m not positive ANNOTATION layers can be removed yet
> without creating a list of specific use/test cases. I could create a before
> -> after syntax page.
I couldn't ponder a use case for annotation layers that couldn't be done
with label styles. If that came up we can back off the deprecation, or
preferably find a alternate way to do it with geomtransform styles or
other....
> **- **Unix build/install procedure (IMHO) is a major (or at
> least minor) new feature that will impact how folks will install multiple
> versions on the same box. Should we provide guidance?
I'll do that.
thanks for the feedback,
thomas
> Steve****
> *From:* mapserver-dev-bounces at lists.osgeo.org [mailto:
> mapserver-dev-bounces at lists.osgeo.org] *On Behalf Of *thomas bonfort
> *Sent:* Tuesday, November 13, 2012 7:14 AM
> *To:* MapServer Dev Mailing List
> *Subject:* Re: [mapserver-dev] 6.2 release notes/announcement****
> feeling somewhat alone here... :)****
> Here's an updated release doc:
> http://ci.mapserver.org/job/docsmaster/lastSuccessfulBuild/artifact/build/html/en/development/announce/6-2.html. If you believe your new feature is insufficiently/incorrectly documented
> or promoted, please be my guest and amend.****
> cheers,****
> thomas****
> On Fri, Nov 9, 2012 at 4:11 PM, thomas bonfort <thomas.bonfort at gmail.com>
> wrote:****
> Devs,****
> I have started a release document [1] for our planned wednesday release.
> This is still a work in progress, and I will be working on the areas marked
> "TODO thomas" in the coming days. There are however a number of points that
> I would need help with, so please have a go at filling in your respective
> parts.****
> The ordering of the new features and the major/minor classifications are a
> first stab, and are open for discussion/modification.****
> regards,****
> thomas****
> [1]
> http://ci.mapserver.org/job/docsmaster/21/artifact/build/html/en/development/announce/6-2.html
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20121113/1ebd59d1/attachment-0001.html>
