[mapserver-dev] RFC-82: Enhanced Layer Metadata Management
Tom Kralidis
tomkralidis at hotmail.com
Mon Oct 1 17:13:27 PDT 2012
> Date: Thu, 27 Sep 2012 17:05:36 +0200
> From: stephan at meissl.name
> To: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] RFC-82: Enhanced Layer Metadata Management
> On 09/25/2012 07:37 PM, Tom Kralidis wrote:
> > devs/PSC: RFC82 can be found at
> > http://mapserver.org/development/rfc/ms-rfc-82.html for review and comment.
> > This RFC proposes generating XML metadata on the fly for layers which
> > don't have any set in the mapfile already.
> > Comments, suggestions and ideas are valued.
> > Thanks
> > ..Tom
> Hi Tom,
> +1, this would definitely be a great addition.
> Maybe extend the "Backwards Compatibility Issues" section a bit as it
> suggests that ows_metadata_path overrides all other metadata parameters
> but as discussed on IRC this is more the other way round.
I've updated the RFC to reflect our discussion.
> What happens if both ows_metadataurl_href and ows_metadata_path are set?
ows_metadata_path is not part of this RFC (I took this out in an earlier commit), the only compatibility is tested against ows_metadataurl_href (which will not override if it exists).
Just in case, the RFC is at https://github.com/mapserver/docs/blob/branch-6-0/en/development/rfc/ms-rfc-82.txt
Should this be in master branch as well?
> In future this could also be a great addition for INSPIRE services but
> would need to support the INSPIRE mandated metadata format.
Agreed, and I have added some verbage to this effect.
Comments from other devs welcome and valued.
Thanks
..Tom
> Thanks,
> Stephan
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20121001/202013e4/attachment.html>
