[mapserver-dev] PHP Mapscript
thomas bonfort
thomas.bonfort at gmail.com
Wed Oct 3 00:04:59 PDT 2012
Frank,
please provide the full backtrace when the code segfaults ("bt" at
the gdb prompt)
thomas
On Wed, Oct 3, 2012 at 8:33 AM, Frank Broniewski <brfr at metrico.lu> wrote:
> Hi,
> I am having problems using mapscript on FreeBSD. I tried alreay the users
> mailing list, but without success. Maybe some developers can help me with my
> problem.
> I am forwarding this from the FreeBSD mailing list. Maybe someone here
> has a clue. I have a problem with PHP Mapscript (the graphics/mapserver
> package). I suppose the problem is in conjunction with the combination
> of lang/php5 (PHP 5.4.6) and Mapserver 6.0.3. Everytime I try to
> initiate a new mapObj in mapscript, PHP segfaults.
> My testscript:
> <?php
> echo ms_GetVersion();
> $map = new mapObj('test.map');
> ms_GetVersion() still works, but the next line ($map = new
> mapObj('test.map')) causes the segmentation fault to happen:
> brfr at frodo# php -f pi.php
> MapServer version 6.0.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ
> SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILESegmentation fault (core dumped)
> An examination of the core with gdb yields
> brfr at frodo# gdb /usr/local/bin/php php.core
> GNU gdb 6.1.1 [FreeBSD]
> Copyright 2004 Free Software Foundation, Inc.
> GDB is free software, covered by the GNU General Public License, and you are
> welcome to change it and/or distribute copies of it under certain
> conditions.
> Type "show copying" to see the conditions.
> There is absolutely no warranty for GDB. Type "show warranty" for details.
> This GDB was configured as "amd64-marcel-freebsd"...
> Core was generated by `php'.
> Program terminated with signal 11, Segmentation fault.
> Reading symbols from /lib/libcrypt.so.5...done.
> Loaded symbols for /lib/libcrypt.so.5
> [snip ...]
> Reading symbols from /usr/local/lib/php/20100525-debug/tidy.so...done.
> Loaded symbols for /usr/local/lib/php/20100525-debug/tidy.so
> Reading symbols from /usr/local/lib/libtidy-0.99.so.0...done.
> Loaded symbols for /usr/local/lib/libtidy-0.99.so.0
> Reading symbols from /libexec/ld-elf.so.1...done.
> Loaded symbols for /libexec/ld-elf.so.1
> #0 0x000000000069a10a in zend_std_get_constructor (object=0x8024762c8)
> at /usr/ports/lang/php5/work/php-5.4.6/Zend/zend_object_handlers.c:1271
> 1271 /usr/ports/lang/php5/work/php-5.4.6/Zend/zend_object_handlers.c: No
> such file or directory.
> in /usr/ports/lang/php5/work/php-5.4.6/Zend/zend_object_handlers.c
> [New Thread 802407400 (LWP 100919/php)]
> (gdb)
> I tried compiling everything back and forth, enabled and disabled all
> kinds of PHP extensions but nothing helps. Segfault is coming always
> back to me. Btw.
> root at frodo# php -v
> PHP 5.4.6 (cli) (built: Sep 26 2012 15:32:23) (DEBUG)
> Copyright (c) 1997-2012 The PHP Group
> Zend Engine v2.4.0, Copyright (c) 1998-2012 Zend Technologies
> works, and all non-mapscript PHP applications seem to run fine.
> So, finally, any tipps to solve this problem are greatly appreceated ...
> Frank
> Frank BRONIEWSKI
> METRICO s.à r.l.
> géomètres
> technologies d'information géographique
> rue des Romains 36
> L-5433 NIEDERDONVEN
> tél.: +352 26 74 94 - 28
> fax.: +352 26 74 94 99
> http://www.metrico.lu
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
