[mapserver-dev] PHP Mapscript
Frank Broniewski
brfr at metrico.lu
Wed Oct 3 00:36:15 PDT 2012
Am 2012-10-03 09:24, schrieb thomas bonfort:
> On Wed, Oct 3, 2012 at 9:21 AM, Frank Broniewski <brfr at metrico.lu> wrote:
>> Hi Thomas,
>> thanks for replying. I wonder if the problem occurs because there are 2
>> versions of GD in use, PHP uses its internal version and mapserver the one
>> from the system, and both mismatch in the minor version. FreeBSD GD is
>> gd-2.0.35_8,1, PHP uses [GD Version] => bundled (2.0.34 compatible)
> That could be a plausible reason, yes. Given the backtrace I'm a bit
> stumped that this is happening when creating a new mapObj, as there is
> no mapserver related function involved.
> thomas
Unfortunately, compiling PHP with the 'onboad' GD seems ... difficult
... at least. I contacted already the mapserver port maintainer on this
issue and he failed to compile PHP with the systems GD version.
Do you have any other clues? The backtrace does not yield anything with
value for me, especially because mapscript (or gd) doesn't even turn up
there.
Frank
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
technologies d'information géographique
rue des Romains 36
L-5433 NIEDERDONVEN
tél.: +352 26 74 94 - 28
fax.: +352 26 74 94 99
http://www.metrico.lu
