[mapserver-dev] PHP Mapscript
Daniel Morissette dmorissette at mapgears.com
Wed Oct 3 05:09:25 PDT 2012
Does the same mapfile work with the mapserv CGI or shp2img?
Does your script crash with any mapfile or just that one?
BTW, Thomas, the mapObj constructor loads and parses the mapfile, so
there is some MapServer code which is called, but nothing in GD yet.
What about REGEX? Is the PHP compiled with the system regex? Difference
in GD and REGEX versions used by PHP and the MapServer core used to be
problems several years ago, but I thought recent PHP versions had solved
those issues since we haven't heard of this type of problems in a while.
Daniel
On 12-10-03 3:36 AM, Frank Broniewski wrote:
> Am 2012-10-03 09:24, schrieb thomas bonfort:
>> On Wed, Oct 3, 2012 at 9:21 AM, Frank Broniewski <brfr at metrico.lu> wrote:
>>> Hi Thomas,
>>> thanks for replying. I wonder if the problem occurs because there are 2
>>> versions of GD in use, PHP uses its internal version and mapserver
>>> the one
>>> from the system, and both mismatch in the minor version. FreeBSD GD is
>>> gd-2.0.35_8,1, PHP uses [GD Version] => bundled (2.0.34 compatible)
>> That could be a plausible reason, yes. Given the backtrace I'm a bit
>> stumped that this is happening when creating a new mapObj, as there is
>> no mapserver related function involved.
>> thomas
> Unfortunately, compiling PHP with the 'onboad' GD seems ... difficult
> ... at least. I contacted already the mapserver port maintainer on this
> issue and he failed to compile PHP with the systems GD version.
> Do you have any other clues? The backtrace does not yield anything with
> value for me, especially because mapscript (or gd) doesn't even turn up
> there.
> Frank
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
