[mapserver-dev] PHP Mapscript
Frank Broniewski brfr at metrico.lu
Wed Oct 3 06:20:36 PDT 2012
Hi Daniel,
thanks for answering. The script segfaults with any mapfile, even those
that are known to work, e.g. shp2img creates a result image. Concering
the REGEX, I don't know where to look. If you can give me a pointer, I
will happily see if that's the cause.
Frank
brfr at frodo> php -i | grep configure
Configure Command =>  './configure'  '--with-layout=GNU'
'--localstatedir=/var' '--with-config-file-scan-dir=/usr/local/etc/php'
'--disable-all' '--enable-libxml' '--enable-mysqlnd'
'--with-libxml-dir=/usr/local' '--with-pcre-regex=/usr/local'
'--with-zlib-dir=/usr' '--program-prefix='
'--with-apxs2=/usr/local/sbin/apxs' '--with-regex=php'
'--with-zend-vm=CALL' '--enable-debug' '--prefix=/usr/local'
'--mandir=/usr/local/man' '--infodir=/usr/local/info/'
'--build=amd64-portbld-freebsd9.0'
brfr at frodo> /usr/local/www/cgi-bin/mapserv -v
MapServer version 6.0.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ
SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Am 2012-10-03 14:09, schrieb Daniel Morissette:
> Does the same mapfile work with the mapserv CGI or shp2img?
> Does your script crash with any mapfile or just that one?
> BTW, Thomas, the mapObj constructor loads and parses the mapfile, so
> there is some MapServer code which is called, but nothing in GD yet.
> What about REGEX? Is the PHP compiled with the system regex? Difference
> in GD and REGEX versions used by PHP and the MapServer core used to be
> problems several years ago, but I thought recent PHP versions had solved
> those issues since we haven't heard of this type of problems in a while.
> Daniel
> On 12-10-03 3:36 AM, Frank Broniewski wrote:
>> Am 2012-10-03 09:24, schrieb thomas bonfort:
>>> On Wed, Oct 3, 2012 at 9:21 AM, Frank Broniewski <brfr at metrico.lu>
>>> wrote:
>>>> Hi Thomas,
>>>> thanks for replying. I wonder if the problem occurs because there are 2
>>>> versions of GD in use, PHP uses its internal version and mapserver
>>>> the one
>>>> from the system, and both mismatch in the minor version. FreeBSD GD is
>>>> gd-2.0.35_8,1, PHP uses [GD Version] => bundled (2.0.34 compatible)
>>> That could be a plausible reason, yes. Given the backtrace I'm a bit
>>> stumped that this is happening when creating a new mapObj, as there is
>>> no mapserver related function involved.
>>> thomas
>> Unfortunately, compiling PHP with the 'onboad' GD seems ... difficult
>> ... at least. I contacted already the mapserver port maintainer on this
>> issue and he failed to compile PHP with the systems GD version.
>> Do you have any other clues? The backtrace does not yield anything with
>> value for me, especially because mapscript (or gd) doesn't even turn up
>> there.
>> Frank
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
technologies d'information géographique
rue des Romains 36
L-5433 NIEDERDONVEN
tél.: +352 26 74 94 - 28
fax.: +352 26 74 94 99
http://www.metrico.lu
