[mapserver-dev] RFC-86: scale dependant DATA substitutions
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Oct 8 10:51:00 PDT 2012
On 10/8/2012 11:32 AM, thomas bonfort wrote:
> On Mon, Oct 8, 2012 at 4:41 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
>> On 10/8/2012 9:02 AM, thomas bonfort wrote:
>>> Devs,
>>> Please take a look and comment on
>>> http://mapserver.org/trunk/development/rfc/ms-rfc-86.html
>> Hi Thomas,
>> Thanks, this looks like an excellent implementation to address the need I
>> identified in bug #3150.
>> I'm a little confused with your first example in the RFC, you have:
>> SCALETOKEN
>> NAME "foobar"
>> VALUES
>> "1000" "1000"
>> "10000" "10000"
>> "1000000" "1000000"
>> END
>> END
>> But the discussion reference 5500, 505000. So that should be cleared up so
>> it is more understandable.
> Steve,
> what this meant is that given the current requested scale, mapserver
> will select the closest defined scaletoken. In the example here,
> 0=>5500 uses the 1000 value
> 5500=>505000 uses 10000
> 505000 and up uses 1000000
> I agree, not very clear... you should only consider the first entry,
> the second one isn't interpreted and is just used as the replacement
> for the token
My confusion is how to determine the ranges. For example, if:
0 < scale <= 1000 use 1000
1000 < scale <= 10000 use 10000
1000000 < scale use 1000000
scale > 1000000 use ??
So, you define three points in the scale range (ie: 1000, 10000,
1000000) so it is not clear what happens above or below these points,
especially above and below the top and bottom ones. If this is better
defined, then maybe there is no need for a default case.
You might do something like:
VALUES
"1000" "1000"
"10000" "10000"
"100000" "100000"
">100000" "1000000"
END
So this would interpret the first column as the maxscaledenom to apply
the token to, with the last one being the default case. I would consider
removing the number after ">" to make it less ambiguous if someone
edited the mapfile and you had something like:
VALUES
"1000" "1000"
"10000" "10000"
"100000" "100000"
"200000" "200000" # added this line
">100000" "1000000" # this is confusing at best, conflicts w "200000"
">" "1000000" # this is more clear and does not depend
# on the user editing two lines
END
Do the scales need to be in ascending or descending order or will you
sort them if they need to be ordered.
Then again, I might be over thinking this.
Thanks,
-Steve
