[mapserver-dev] Add support for using all OGR style parameters
Tamas Szekeres szekerest at gmail.com
Tue Oct 23 02:51:39 PDT 2012
Hi All,
Any comments in this topic?
Best regards,
Tamas
2012/9/29 Tamas Szekeres <szekerest at gmail.com>
> Hi All,
> Currently the OGR driver supports to get only of the various OGR label
> style parameters as special attributes (ie. OGR:LabelText or OGR_LabelAngle)
> We would like to use further style parameters in mapserver so I've added a
> sample implementation for this in my forked repo:
> https://github.com/szekerest/mapserver/commit/78c2e56c0e5d9a5da68ed6719881392230a587f3
> This implementation provides support to use the following special
> attributes
> OGR:LabelParam[paramId]
> OGR:BrushParam[paramId]
> OGR:PenParam[paramId]
> OGR:SymbolParam[paramId]
> where [paramId] is an integer value according to
> the OGRSTLabelParam, OGRSTBrushParam, OGRSTPenParam, OGRSTSymbolParam
> enumerations in ogr_core.h<http://www.gdal.org/ogr/ogr__core_8h-source.html>
> With this addition we can easily map feature styles (ie mapinfo styles) to
> classes for example by using *CLASSITEM [OGR:BrushParam2]* which refers
> to the mapinfo brush id.
> What are the opinions about such kind of addition?
> BTW: the ogr autostyle mechanism provides support to map style id-s to
> mapserver symbols but as of mapserver 6.0 this can be used less
> efficiently, since many of the symbol parameters (like patterns) has been
> moved to the style sections. So we'd prefer to map styleid-s to classes
> instead of symbols then.
> Best regards,
> Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20121023/13886e3e/attachment.html>
