[mapserver-dev] beta3 today?
thomas bonfort thomas.bonfort at gmail.com
Wed Sep 5 05:32:45 PDT 2012
does anyone have some work in progress that would prevent us from
releasing a beta3 today?
if not, I'll have a crack at it this evening (old continent timezone).
changes since beta2:
|2012-09-05 14:22:12 +0200|Thomas Bonfort|build and clean
mapscriptvars utility file (#4440)|
|2012-09-05 14:14:50 +0200|Thomas Bonfort|fix ogc "equals" operator
after rfc 64 (#3613)|
|2012-09-05 14:11:57 +0200|Thomas Bonfort|allow empty wms styles (#4355)|
|2012-09-05 13:32:02 +0200|Thomas Bonfort|deactivate postgis getextent
function (#4039)|
|2012-09-05 13:26:43 +0200|Thomas Bonfort|avoid token collisions in
parser when reading char by char (#4012)|
|2012-09-05 13:19:44 +0200|Thomas Bonfort|adjust letterspacing on
follow labels (#4404)|
|2012-09-04 20:47:34 +0200|szekerest|SDE: Fix for the crash with NCLOB
type (#3001)|
|2012-09-03 18:55:09 +0200|Stephan Meissl|Fixing wms_style_name in
GetMap requests (#4439).|
|2012-08-31 17:30:53 +0200|Thomas Bonfort|add branch-6-2 to stable
merge script (#4437)|
|2012-08-30 14:49:57 +0000|Alan Boudreault|Fix queryByFilter segfault
in SWIG...|
|2012-08-30 14:18:18 +0000|Alan Boudreault|Fix in msQueryBy* functions
to support the startindex from MapScript|
|2012-08-30 13:30:24 +0000|Alan Boudreault|Modified WFSGetFeature to
support maxfeatures across layers rather than within (#4011)|
|2012-08-30 10:39:12 +0200|Stephan Meissl|Updating HISTORY.TXT|
|2012-08-29 16:40:20 +0000|Alan Boudreault|Fix segfault in
queryByFilter function in PHP/MapScript|
|2012-08-29 15:27:01 +0000|Alan Boudreault|Fix another issue in
symbolObj.getImage related to internal renderer object|
|2012-08-29 15:59:49 +0200|Stephan Meissl|Adjusting to GMLCOV 1.0
corrigendum 1.0.1 (#4003).|
|2012-08-29 15:18:14 +0200|Stephan Meissl|Adjusting to WCS 2.0 Core
corrigendum 2.0.1 (#4003).|
|2012-08-29 13:47:31 +0200|Stephan Meissl|Updating HISTORY.TXT|
|2012-08-29 13:32:47 +0200|Stephan Meissl|Adjusted support for the
mediatype multipart/related in WCS 2.0. Related to issue #4003.|
|2012-08-28 18:46:11 +0000|Alan Boudreault|Fix symbolObj.getImage seg
fault in PHP/MapScript|
|2012-08-28 17:16:38 +0000|Alan Boudreault|Added history note|
|2012-08-28 17:15:38 +0000|Alan Boudreault|Fix bad handling of
startindex with some drivers (#4011)|
|2012-08-28 18:37:32 +0200|Stephan Meissl|Correcting HISTORY.TXT|
|2012-08-28 18:11:45 +0200|Stephan Meissl|Small adjustment in fixing
bugs with WCS 1.1/2.0 with VSIMEM (#4369)|
|2012-08-28 17:42:46 +0200|Stephan Meissl|Backporting: WCS: Set layer
projection to map's one if not set (#4079).|
|2012-08-25 18:11:14 +0200|Thomas Bonfort|fix header line terminations
on multipart org output (#4430)|
|2012-08-25 18:04:13 +0200|Thomas Bonfort|fix rendering of cached
pixmap symbols on lines (#4433)|
|2012-08-22 18:34:42 +0200|Thomas Bonfort|fix double free on queryitem|
|2012-08-22 14:04:21 +0200|Thomas Bonfort|mark errors as reported for
inimage mode (#4142)|
|2012-08-21 14:22:43 +0000|Alan Boudreault|Fix regression related to
sld expression (#3929)|
|2012-08-22 12:42:55 +0200|Thomas Bonfort|add erroneously removed
statement (#4424)|
|2012-08-22 12:36:42 +0200|Thomas Bonfort|don't fail on shapefile with
no items (#4424)|
|2012-08-22 09:00:09 +0200|Thomas Bonfort|last fix related to #4229|
|2012-08-21 17:27:17 +0200|Thomas Bonfort|fixes related to #4429|
|2012-08-21 17:17:53 +0200|Thomas Bonfort|fix second occurence of #4424|
|2012-08-21 17:09:34 +0200|Thomas Bonfort|avoid segfault on dbf with
less records than shp (#4424)|
|2012-08-21 14:53:09 +0200|Thomas Bonfort|use \r\n as header
lineendings instead of \n (#4430)|
|2012-08-21 00:47:07 +0200|szekerest|Fix SLD label rendering with
mapserver 6.2 (#4429)|
|2012-08-20 13:25:48 +0200|Thomas Bonfort|WCS: Set layer projection to
map's one if not set (#4079)|
|2012-08-18 15:53:29 +0200|szekerest|MSSQL: Fix for the crash if
uniqueidentifier is specified as fid column (#4427)|
|2012-08-14 18:26:43 +0000|Jerome Villeneuve Larouche|Fix for issue 4225|
|2012-08-14 09:50:11 +0200|szekerest|Fixed the OGR driver to use point
or line spatial filter geometries in degenerated cases (#4420)|
|2012-08-13 11:48:59 +0200|Fabian Schindler|Added support for the
mediatype multipart/related in GetCoverage requests. Related to issue
#4003.|
|2012-08-11 12:54:57 +0200|Thomas Bonfort|avoid unchecked null
metadata values (#4419)|
|2012-08-10 12:48:40 +0200|Thomas Bonfort|add perl mapscript ignores|
|2012-08-10 11:07:07 +0200|Thomas Bonfort|fix segfault on WFS 1.1
namespace prefix (#4419)|
|2012-08-07 15:53:59 +0200|Thomas Bonfort|fix buffer size for
onlineressource with https and non-standard port (#4413)|
|2012-08-07 13:47:04 +0200|Thomas Bonfort|return exception only on
failed wfs getfeature preamble|
|2012-08-07 12:29:19 +0200|Thomas Bonfort|fix segfault in msSLDApplySLD (#4112)|
|2012-08-06 21:07:15 -0500|Stephen Lime|Initialize record.resultindex
to -1 in msQueryByIndex()... #4416|
|2012-07-23 12:14:16 +0200|Thomas Bonfort|avoid segfault on failed
reprojected point (#4403)|
|2012-08-02 17:00:57 +0200|szekerest|Fix msCopyClass causing memory corruption|
|2012-07-04 15:19:11 +0200|Fabian Schindler|Fixing bugs with WCS
|2012-06-29 20:24:50 +0000|Jerome Villeneuve Larouche|Added
labelleader and some minor modification to the test|
|2012-06-29 14:07:32 +0000|Jerome Villeneuve Larouche|Updated XML
support for 6.2|
|2012-06-29 08:38:41 -0300|Daniel Morissette|Add ref to MapScript fix
for PHP 5.4 (#4309)|
|2012-06-28 18:57:19 -0300|Jeff McKenna|backport PHP 5.4 mapscript
updates to branch-6-0|
|2012-06-15 19:13:47 +0000|Alan Boudreault|Fix msOGREscapeSQLParam
could return random data (#4335)|
|2012-06-05 16:20:29 +0200|Håvard Tveite|Updated migration guide -
removal of DUMP (#3830)|
|2012-05-30 16:21:27 +0200|Fabian Schindler|Fixed bug in format
enumeration. The map.web.metadata key wcs_formats is now also taken
into account for each layer (in WCS 1.1).|
|2012-05-30 15:37:02 +0200|Fabian Schindler|Removed advertising of
supported formats in WCS 2.0 CoverageDescriptions as this is not
included in the standard.|
|2012-05-30 15:35:34 +0200|Fabian Schindler|Parse available formats
from map.web.metadata field 'wcs|ows_formats' if given. Now for WCS
1.1. Not possible for WCS 1.0 since this Capabilities does not include
a supported formats section.|
|2012-05-30 12:38:01 +0200|Fabian Schindler|Parse available formats
from map.web.metadata field 'wcs|ows_formats' if given.|
