[mapserver-dev] Request for review/comments on RFC 85 (Contour Layer Rendering)
Alan Boudreault
aboudreault at mapgears.com
Thu Sep 20 11:17:57 PDT 2012
oh, this might not affect the issue you pointed...
On 12-09-20 02:15 PM, Alan Boudreault wrote:
> Frank,
> As discussed with EvenR, the ideal process would be to generate another
> raster dataset (frmt_mem) using GDALRasterIO() to only get what we need
> from the raster source. This would take the extent, window size, etc.
> into account. After, we would pass this modified dataset to
> GDALContourGenerate.
> Do you agree with that solution?
> Alan
> On 12-09-20 01:11 PM, Frank Warmerdam wrote:
>> Alan,
>> This looks cool, and I like the nice general way of specifying
>> different intervals at different scales.
>> I'm mildly concerned that GDALContourGenerate is really producing more
>> detailed vector information than is likely necessary if you are
>> running it on elevation raster data at the map display resolution.
>> It will produce lots of basically one pixel vectors which need to be
>> styled. I'm not sure what the fix for that is. One thing that might
>> help would be supporting a downsampling factor where the elevation
>> data would actually be loaded at a somewhat lower resolution than the
>> displayed map and generate the contours from that.
>> In any event, assuming the performance is adequate it will work fine
>> as is, and exactly how the contours are produced could be changed in
>> the future.
>> It is sweet to see my contour generator getting more use!
>> Best regards,
>> Frank
>> On Thu, Sep 20, 2012 at 8:40 AM, Alan Boudreault
>> <aboudreault at mapgears.com> wrote:
>>> Hi devs,
>>> I'd like to request some review on a pending RFC regarding support for
>>> contour layer rendering.
>>> Please see
>>> https://raw.github.com/mapserver/docs/master/en/development/rfc/ms-rfc-85.txt
>>> The official rfc page should be updated in about a hour.
>>> http://mapserver.org/trunk/development/rfc/ms-rfc-85.html.
>>> Thanks,
>>> Alan
>>> Alan Boudreault
>>> http://www.mapgears.com/
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Alan Boudreault
