[mapserver-dev] the state of msautotest
Daniel Morissette
dmorissette at mapgears.com
Fri Sep 21 14:32:15 PDT 2012
And I second that big time! Thank you very much Thomas for your work and
your patience.
Daniel
On 12-09-21 5:29 PM, Lime, Steve D (DNR) wrote:
> Thanks for setting all this up and being so incredibly productive!
> ________________________________________
> From: mapserver-dev-bounces at lists.osgeo.org [mapserver-dev-bounces at lists.osgeo.org] on behalf of thomas bonfort [thomas.bonfort at gmail.com]
> Sent: Friday, September 21, 2012 3:55 AM
> Cc: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] the state of msautotest
> @Oliver: Thanks for suggesting the travis platform, it's a perfect fit
> for what we are testing
> @Mike: Thanks for the hosting offer. In the current state, travis-ci
> is largely sufficient and better than what we could have setup on our
> own in a reasonable amount of time. However providing a remotely
> accessible "reference" platform where devs can test their changes and
> add expected results might be a usefull tool. Is this something devs
> want? Mike, is opening up an ubuntu vm something possible?
> Just a quick followup on the rest:
> - There's an autotest wiki page in place here:
> https://github.com/mapserver/mapserver/wiki/Test-Suite
> - The Travis continuous integration is activated and operational for
> the 6.2 and master branches. The test suite will be run on any commit
> to those branches, as well as on all pull-requests submitted to the
> issue tracker (which is another reason to use pull requests rather
> than attaching patches, example here:
> https://github.com/mapserver/mapserver/pull/4044 )
> - I've added a number of autotests that need a postgis db to run on.
> They will evidently fail if such a db isn't available. There is
> however a script that will automatically create/populate such a db for
> you at the root of msautotest. These tests are there to validate some
> db specific features (filtering, TIME) as well as provide valgrind
> info.
> - There's a "make test" target in our mapserver repo, which uses the
> binaries from the source directory (i.e. there's no need to make
> install before running the test suite). The make target should ensure
> that the test suite data is downloaded on first run, however it will
> not be updated automatically, which means it is up to you to run "git
> submodule update" to catch up with updates to msautotest. The tests
> *will* fail if not all compilation options have been activated, c.f.
> the "reference platform" on the wiki page.
> Please provide any feedback you might have with these new tools.
> regards,
> thomas
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
