[mapserver-dev] [UVRASTER] reprojected layers
Yves Jacolin
yves.jacolin at camptocamp.com
Wed Apr 3 00:36:53 PDT 2013
Thanks Alan,
I confirm that your changes get MapServer working correctly with
reprojection for UV Raster layer!
Thanks again,
Y.
2013/3/27 Yves Jacolin <yves.jacolin at camptocamp.com>
> Alan,
> When I received your answer I was discussing with my packager to know when
> he
> built it and we conclude that it was too old. Your answer confirme this.
> I am lucky because we have a mapserver-6.3dev package ready to be tested
> here
> Thanks,
> Y.
> Le mercredi 27 mars 2013 09:20:15 Alan Boudreault a écrit :
> > Can you verify if this changeset is in your build:
> > https://github.com/mapserver/mapserver/issues/4495
> > Alan
> > On 13-03-27 09:10 AM, Yves Jacolin wrote:
> > > Alan,
> > > Thanks for your reply. We did some tests here and here some
> information:
> > > * with a working UV raster layer in WMS:
> > > we changed WIDTH/HEIGHT ratio in regards with BBOX ratio and uvraster
> > > layer
> > > doesn't changed anymore.
> > > * reprojection:
> > > We had EPSG:3857 code and send a request to the WMS server for the
> > > uvraster
> > > layer. We can't dispaly any feature, either using arrow or point.
> > > MapServer
> > > log (DEBUG) 5 shows some informations on feature which seems correct
> to me
> > > (raster cells are correctly reprojected in 3857).
> > > As soon as we are using UVRASTER connectiontype, feature disappear.
> Indeed
> > > we did several test and one of them was just display netcddf files. We
> > > are currently using a tileindex with WMS-T and we wanted to be sure
> that
> > > there is no other issue.
> > > Hope I am clear, I am available in IRC if needed. About your question:
> any
> > > test case you could run, I don't know, did you test EPSG:3857? Did
> you see
> > > the same issue from us in regards with ratio changes?
> > > One more information which can be important: MapServer version 6.1-dev
> > > [...] I don't know when we built it ...
> > > Y.
> > > Le lundi 25 mars 2013 15:19:53 Alan Boudreault a écrit :
> > >> Yves,
> > >> Yes, I remember that the reprojection was working with UVRASTER. Any
> > >> test case I could run?
> > >> Alan
> > >> On 13-03-25 12:29 PM, Yves Jacolin wrote:
> > >>> Hello,
> > >>> Is it possible to reproject an "UVRaster" layer (ie vector field)
> from
> > >>> 4326 to 3857?
> > >>> "DEBUG 5" mode shows me that raster cells are correctly reprojected
> to
> > >>> 3857
> > >>> but I can't even display it with a simple circle symbol (ie without
> > >>> using
> > >>> UV_ANGLE or UV_LENGTH).
> > >>> Thanks,
> > >>> Y.
> Responsable Formation et Support
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel (France) : +33 4 79 26 57 98
> Tel (Suisse) : 021 619 10 43 (new)
> Mob. : +33 6 18 75 42 21
> Fax : 04 79 70 15 81
> Mail : yves.jacolin at camptocamp.com
> http://www.camptocamp.com
Tel (Suisse) : 0 21 619 10 43 (new)
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130403/3f10c0df/attachment.html>
