[mapserver-dev] OGR/MySQL Layer executes SQL query twice
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Wed Apr 10 11:06:02 PDT 2013
Is there a way to test your theory independent of MapServer using OGR only? I don't know the MapServer OGR driver well but I can't imagine this is normal.
Steve
-----Original Message-----
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of deuce2367
Sent: Tuesday, April 09, 2013 9:20 AM
To: mapserver-dev at lists.osgeo.org
Subject: [mapserver-dev] OGR/MySQL Layer executes SQL query twice
I'm using Mapserver 6.0.2 and GDAL 1.7.2 and have created a mapfile with an OGR/MySQL layer. The SQL query that retrieves the spatial data is fairly slow, takes about 8-10 seconds. I've noticed that whenever I render the layer (via the mapserv binary or via the shp2img utility) that the query executes two times. I thought this was maybe some sort of introspection/reflection issue where perhaps OGR is trying to characterize the data somehow so I made sure to create and populate the geometry_columns table but that doesn't seem to help, it's still running the SQL query twice.
Incidentally it's also performing 2 describes and 2 'select from geometry_columns...' as well.
Is this normal and expected?
I apologize if this is a repeat, I didn't find any references to this observation in my searches. Appreciate any help,
-Andy Smith
View this message in context: http://osgeo-org.1560.x6.nabble.com/OGR-MySQL-Layer-executes-SQL-query-twice-tp5045536.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
mapserver-dev mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
