[mapserver-dev] Time for 6.2.1?
thomas bonfort
thomas.bonfort at gmail.com
Wed Apr 10 11:58:22 PDT 2013
Martin,
I'll cherrypick. I'll let you remilestone and reopen that bug so this
doesn't slip through.
regards,
thomas
On 10 April 2013 20:50, Martin Kofahl <martin.kofahl at gmail.com> wrote:
> Bugfix #4627 for parsing kvp in post requests should also go in 6-2.
> Thomas, can you cherry-pick or shall I open a new pull request? Martin
> 2013/4/10 Jeff McKenna <jmckenna at gatewaygeomatics.com>
>> On 2013-04-10 11:32 AM, Lime, Steve D (MNIT) wrote:
>> > Talked about this at the sprint... There are 21 closed issues and only
>> > one open. The open one is related to building SDE on 64-bit linux. With
>> > the cmake changes with 6.4 it's probably best to address it there anyway
>> > (I'll re-milestone it). Thoughts?
>> Good plan. I'd also like to move the sprint docs work into branch-6-2
>> for this release (my goal is to do this today or tomorrow).
>> I also will do much needed MS4W release for 6.2.1
>> -jeff
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130410/f8a37186/attachment.html>
