[mapserver-dev] Scales and raster maps
Frank Broniewski
brfr at metrico.lu
Thu Aug 8 23:19:21 PDT 2013
Hello all,
yesterday I posted a thread on the Mapproxy list concerning map scales
and the DPI setting [1]:
> TL;DR
> The scale isn't the scale and a screen doesn't have dots so it doesn't have DPI. Don't do scale dependant calculations on fictional units.
This is something that keeps my mind busy for quite some time. We're
assuming a certain DPI value, which doesn't make any sense for screen
mediums at all, and this DPI value isn't probably correct for most of
the time. Please read my post on the mapproxy list for a more verbose
discussion why raster map scales -stink- are IMO not good.
Since this DPI value is used for scale computations and scale is used
for many vital parts in a map's composition I'm having a sore tummy (is
that a correct phrase?) all the time. You define your layout based on
scale and you define layer visibility on scale and probably even more
settings.
Issues arise also when tuning your client vs. server application and
both have a different understanding of scale and / or this DPI setting.
What I'd like to have and propose hereby is a scale independent ratio
like most Javascript clients and also Mapproxy have which is the
resolution. This is a ground unit per pixel ratio and is something that
is valid throughout all screen pixel densities.
Would this be possible to implement along the DPI/scale setting? I think
this would be handy to have and would be also more future proof than the
DPI/scale setting. Since this measurement is not based on an arbitrary
estimated value but is based on real output dimensions that is the
pixel. Well, most of the time I mean ;-)
Many thanks for reading,
Frank
[1]
http://osgeo-org.1560.x6.nabble.com/MapProxy-Seeding-in-a-certain-scale-tp5071082p5071464.html
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
technologies d'information géographique
rue des Romains 36
L-5433 NIEDERDONVEN
tél.: +352 26 74 94 - 28
fax.: +352 26 74 94 99
http://www.metrico.lu
