[mapserver-dev] Mapserver thread safety
thomas bonfort
thomas.bonfort at gmail.com
Tue Aug 13 09:20:39 PDT 2013
Nice catch!
Returning a reference to epsgCode in that function is, to my
knowledge, to the best undefined behavior, clearly not thread safe,
and should be fixed.
thomas
On 13 August 2013 16:31, <Michel.Dastous at bentley.com> wrote:
> About WFS/WMS thread safety, looking at mapows.c I found a single static
> variable (epsgCode) used in msOWSGetEPSGProj().
> Instead of returning a static pointer, the method could easily take a buffer
> + buffer size as parameters… Not a big deal except that 62 calls to that
> function will have to be modified.
> Is this the only thing that make WFS/WFS server non thread safe?
> Thanks !
> From: Michel Dastous
> Sent: Tuesday, August 13, 2013 9:45 AM
> To: 'Umberto Nicoletti'
> Cc: MapServer Dev Mailing List
> Subject: RE: [mapserver-dev] Mapserver thread safety
> Thank you very much! I will test it as soon as possible.
> From the page you sent me I realized that WMS/WFS server is not thread safe
> (“WMS/WFS server: static data used for state of dispatcher”). Is there any
> plan to fix this ? I could not find any ticket about this
> Thanks.
> From: Umberto Nicoletti [mailto:umberto.nicoletti at gmail.com]
> Sent: Tuesday, August 13, 2013 8:49 AM
> To: Michel Dastous
> Subject: Re: [mapserver-dev] Mapserver thread safety
> FYI, I've opened this pull request which should fix the Oracle spatial issue
> you are seeing:
> https://github.com/mapserver/mapserver/pull/4729
> Let me know if it works for you.
> BR,
> Umberto
> On Tue, Aug 13, 2013 at 8:23 AM, Umberto Nicoletti
> <umberto.nicoletti at gmail.com> wrote:
> Michel,
> this page attempts to keep track of which Mapserver components are thread
> safe:
> http://mapserver.org/faq.html#is-mapserver-thread-safe
> it must not be completely up to date as, as you found out, Oracle is listed
> as safe, while it's not.
> As for fixing it, it should be relatively easy as those two variables can be
> made local to the functions using them.
> Please open an issue and I will look into it asap.
> Umberto
> On Mon, Aug 12, 2013 at 9:44 PM, <Michel.Dastous at bentley.com> wrote:
> Hi all,
> I’ve been testing mapserver and its c# mapscript API for a while now, and I
> have noticed that making simultaneous Draw request on multiple maps
> containing Oracle layer will end up in memory corruption. No surprise here
> since maporaclespatial.c uses static variables (ordinates_tdo and
> ordinates).
> My question is: Does anyone have already evaluated how much work it would
> require to make it thread safe (i.e remove those static variables from the
> code) ?
> Furthermore, I have also tested the MSSQL plugin which is stable under same
> conditions, unfortunately it doesn’t seem to scale very well my 4 core
> machines with maximum CPU usage of 15%.
> I don’t think the problem come from mapserver’ s rendering engine… when
> drawing a map with inlined data, I could easily reach a 90% usage.
> So any suggestions/information would be welcome.
> Thanks.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
