[mapserver-dev] RFC 102: Styleitem Javascript Plugin
    Lime, Steve D (MNIT)
    Steve.Lime at state.mn.us
    Mon Aug 19 10:52:29 PDT 2013
I remember chatting about this a bit at FOSS4G-NA. Javascript has such broad support these days it seems a reasonable choice for an embedded language. Could presumably consider others. Have you actually got this integration working even in just a simple way? I'd be interested in seeing code. I could see templates evolving this way. That is, we expose the result set and other query/render time values. With the other potential uses out there we should make sure exposing objects can be done using a standard syntax.
Steve
________________________________________
From: mapserver-dev-bounces at lists.osgeo.org [mapserver-dev-bounces at lists.osgeo.org] on behalf of Alan Boudreault [aboudreault at mapgears.com]
Sent: Monday, August 19, 2013 12:27 PM
To: thomas bonfort
Cc: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] RFC 102: Styleitem Javascript Plugin
All,
- V8 allows us to embed a javascript interpretor in an application. It
implements ECMAScript 5th edition and runs on Windows, Mac and Linux.
The idea behind its addition is to have a scripting language to
implement various plugins. The one suggested here is a plugin that
generates styles, but we could imagine some other use cases: ie. a new
datasource that return the shape object from a javascript plugin or
maybe the ability to use a javascript plugin to extend the geomtransform
for a specific case.
V8 provide an embeded javascript engine (syntax, interpretation,
execution) and it is absolutely not related to anything *client-side*
(browser). So no, it is not needed for scribeUI.
- The shapeObj will be exposed as a wrapper created for the v8 engine. I
will only expose shape attributes for this RFC. A new rfc will be
written later for a *complex symbology plugin* and the geometry will be
expose for this need.
- nothing to push in a branch yet
On 13-08-19 12:50 PM, thomas bonfort wrote:
> Alan,
> - For those of us who haven't followed up closely on the v8 engine and
> its possibilities, could you expand your RFC or follow up here with
> some use-cases where this would be used in mapserver? Is this
> something that is needed for scribeUI?
> - How and what do you plan on exposing of a shapeObj to V8? Direct
> member access or wrappers? Will you expose only attributes or also
> geometry?
> - You seem to have some or most of the code ready? Can you push your
> branch publicly?
> thanks,
> Thomas
> On 19 August 2013 18:17, Alan Boudreault <aboudreault at mapgears.com> wrote:
>> Devs,
>> Please take a look at RFC 102 which propose the addition of a styleitem
>> javascript plugin as an alternative to style our features.
>> http://mapserver.org/development/rfc/ms-rfc-102.html
>> I'll be calling for vote on it next week.
>> Thanks,
>> Alan
>> Alan Boudreault
>> http://www.mapgears.com/
>> mapserver-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Alan Boudreault
