[mapserver-dev] Mapserver thread safety
Umberto Nicoletti
umberto.nicoletti at gmail.com
Thu Aug 22 12:41:53 PDT 2013
We managed to push a fix in time for 6.4.0, which we will improve in later
release.
If you want, you could test the recently released betas:
http://mapserver.org/download.html#development-releases
BR,
Umberto
On Thu, Aug 22, 2013 at 9:13 PM, <Michel.Dastous at bentley.com> wrote:
> What's the status about this? I guess a fix for 6.4.0 release is too late?
> Thanks
> -----Original Message-----
> From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
> Sent: Tuesday, August 13, 2013 12:21 PM
> To: Michel Dastous
> Cc: Umberto Nicoletti; MapServer Dev Mailing List
> Subject: Re: [mapserver-dev] Mapserver thread safety
> Nice catch!
> Returning a reference to epsgCode in that function is, to my knowledge, to
> the best undefined behavior, clearly not thread safe, and should be fixed.
> thomas
> On 13 August 2013 16:31, <Michel.Dastous at bentley.com> wrote:
> > About WFS/WMS thread safety, looking at mapows.c I found a single
> > static variable (epsgCode) used in msOWSGetEPSGProj().
> > Instead of returning a static pointer, the method could easily take a
> > buffer
> > + buffer size as parameters… Not a big deal except that 62 calls to
> > + that
> > function will have to be modified.
> > Is this the only thing that make WFS/WFS server non thread safe?
> > Thanks !
> > From: Michel Dastous
> > Sent: Tuesday, August 13, 2013 9:45 AM
> > To: 'Umberto Nicoletti'
> > Cc: MapServer Dev Mailing List
> > Subject: RE: [mapserver-dev] Mapserver thread safety
> > Thank you very much! I will test it as soon as possible.
> > From the page you sent me I realized that WMS/WFS server is not thread
> safe
> > (“WMS/WFS server: static data used for state of dispatcher”). Is there
> any
> > plan to fix this ? I could not find any ticket about this
> > Thanks.
> > From: Umberto Nicoletti [mailto:umberto.nicoletti at gmail.com]
> > Sent: Tuesday, August 13, 2013 8:49 AM
> > To: Michel Dastous
> > FYI, I've opened this pull request which should fix the Oracle spatial
> > issue you are seeing:
> > https://github.com/mapserver/mapserver/pull/4729
> > Let me know if it works for you.
> > BR,
> > Umberto
> > On Tue, Aug 13, 2013 at 8:23 AM, Umberto Nicoletti
> > <umberto.nicoletti at gmail.com> wrote:
> > Michel,
> > this page attempts to keep track of which Mapserver components are
> > thread
> > safe:
> > http://mapserver.org/faq.html#is-mapserver-thread-safe
> > it must not be completely up to date as, as you found out, Oracle is
> > listed as safe, while it's not.
> > As for fixing it, it should be relatively easy as those two variables
> > can be made local to the functions using them.
> > Please open an issue and I will look into it asap.
> > Umberto
> > On Mon, Aug 12, 2013 at 9:44 PM, <Michel.Dastous at bentley.com> wrote:
> > Hi all,
> > I’ve been testing mapserver and its c# mapscript API for a while now,
> > and I have noticed that making simultaneous Draw request on multiple
> > maps containing Oracle layer will end up in memory corruption. No
> > surprise here since maporaclespatial.c uses static variables
> > (ordinates_tdo and ordinates).
> > My question is: Does anyone have already evaluated how much work it
> > would require to make it thread safe (i.e remove those static
> > variables from the
> > code) ?
> > Furthermore, I have also tested the MSSQL plugin which is stable under
> > same conditions, unfortunately it doesn’t seem to scale very well my 4
> > core machines with maximum CPU usage of 15%.
> > I don’t think the problem come from mapserver’ s rendering engine…
> > when drawing a map with inlined data, I could easily reach a 90% usage.
> > So any suggestions/information would be welcome.
> > Thanks.
> > mapserver-dev mailing list
> > mapserver-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130822/af8c7f33/attachment.html>
