[mapserver-dev] RFC 101: Content Dependant Legend Rendering
thomas bonfort thomas.bonfort at gmail.com
Fri Aug 23 02:12:57 PDT 2013
Worth,
Independantly of this RFC, the concept of legend rendering when using
attribute binding is ill-defined, and this is something that cannot be
fixed by code alone. If your use-case results in a tractable legend
rendering (i.e. only a handfull of attribute values get binded) then I
would suggest that you adapt your code to dynamically create those
CLASSes, and drop the attribute binding alltogether.
thomas
On 22 August 2013 02:17, Worth Lutz <wal3 at mindspring.com> wrote:
> Thomas,
> This looks like something I need! One question though.
> If I have a layer with one class and the style defined by attributes
> selected by my DATA statement query, will this create all those legend
> icons?
> Example:
>  CLASS
>     #NAME "AaA"
>     #EXPRESSION "AaA"
>     STYLE
>       COLOR [color]
>       OUTLINECOLOR [outlinecolor]
>     END
>     INCLUDE "layers/soil_label.inc"
>   END
> I do see the one problem. You cannot use an attribute for the NAME which is
> what shows up in the legend.
> Where this would be helpful is where I have many different classes but only
> several (5-10) may show up on one zoomed in view. I can select the colors
> from a small palette and assign them in my query. I just cannot figure out
> how to get a legend.
> I hope this makes sense and my spark an idea for a solution.
> Thanks,
> Worth Lutz
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of thomas bonfort
> Sent: Friday, July 19, 2013 9:50 AM
> To: MapServer Dev Mailing List
> Subject: [mapserver-dev] RFC 101: Content Dependant Legend Rendering
> Devs,
> Please find RFC 101 which proposes an extension to GetLegendRequest
> image results to only include legend icons for features that are
> actually present in a given map view
> https://github.com/mapserver/docs/blob/5398e449f6307419e2557a5a5ca0404bab827
> 728/en/development/rfc/ms-rfc-101.txt
> and soon at: http://mapserver.org/development/rfc/ms-rfc-101.html
> I'll be calling for vote on it next week, in time for our upcoming 6.4
> feature-freeze.
> Best regards,
> Thomas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 2013.0.3349 / Virus Database: 3204/6501 - Release Date: 07/18/13
