[mapserver-dev] [vote] Call for vote on RFC98
thomas bonfort
thomas.bonfort at gmail.com
Thu Aug 29 01:11:39 PDT 2013
Devs,
I would like to call for vote on RFC98
http://mapserver.org/development/rfc/ms-rfc-98.html. In addition to
the text rendering overhaul, that branch will also pull in the
following changes:
- RFC99 GD removal
- Removal of deprecated annotation layers
- added some compiler annotations to warn for unused return values
- added some compiler annotations to indicate likely/unlikely branch
conditions (to help the optimizer)
- renamed the WITH_THREADS cmake flag to WITH_THREAD_SAFETY to better
indicate its role
There are still a couple of points I would like to address before the
7.0 release (namely cleaner handling of BITMAP fonts (more to come on
this later on), and maybe revisiting the font/glyph caching), but in
any case the code is usable right away and passes all tests.
I'll start with my +1.
regards,
thomas
