[mapserver-dev] Double backslashes in Windows UNC pathnames should be escaped by the mapfile writer.
Tamas Szekeres szekerest at gmail.com
Fri Aug 30 03:51:16 PDT 2013
Devs,
I've added issue 4747
<https://github.com/mapserver/mapserver/issues/4747>regarding to the
UNC pathnames on Windows which is not handled correctly by
the mapfile writer. Actually the double backslashes are written directly to
the file (without escaping) while the parser reads only one backslash in
this case. Do you think it could be fixed by simply replacing the
backslashes with double backslashes when writing the file (for example in
the CONNECTION and DATA sections)?
Best regards,
Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130830/43f08610/attachment.html>
