[mapserver-dev] libsvg-cairo / librsvg [vote]
thomas bonfort
thomas.bonfort at gmail.com
Mon Dec 2 05:34:51 PST 2013
Martin,
It would seem you are right, I would however however check with the
librsvg authors directly if you need an authoritative answer, given
that the GPL COPYING file is also present.
regards,
thomas
On 29 November 2013 15:21, Martin Icking <martin.icking at bentley.com> wrote:
> On the librsvg licensing issue:
> After noticing that this library was noted to be dual licensed (GPL / LGPL)
> in Wikipedia <http://en.wikipedia.org/wiki/Librsvg> I had a look at the
> sources <https://git.gnome.org/browse/librsvg/tree/> . And in fact there we
> find both a COPYING (GPL) and a COPYING.LIB (LGPL) file.
> So do you agree that librsvg can be handled like other LGPL'ed libraries
> Mapserver uses?
> Best regards
> Martin
> View this message in context: http://osgeo-org.1560.x6.nabble.com/libsvg-cairo-librsvg-vote-tp5068511p5091887.html
> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
