[mapserver-dev] Enable/disable OWS layers by IP list
Tamas Szekeres
szekerest at gmail.com
Thu Feb 14 07:47:55 PST 2013
Steve,
With regards to disabling the stock CGI modes I wonder if we have the same
issue for example when limiting access to certain WMS layers by using the
wms_enable_request setting.
For a workaround, I think it would be easy to implement a similar parameter
(for example ms_disable_modes) in the WEB section to control which modes
are not to be handled.
For example "ms_disable_modes" "*" would dispatch only those requests
where explicit mode is not set by URL. I notice we also have a modeStrings
array in mapservutil.c which could provide the option to disable the modes
selectively, something like:
"ms_disable_modes" "MAP BROWSE LEGEND"
What is you opinion?
Best regards,
Tamas
2013/2/14 Lime, Steve D (MNIT) <Steve.Lime at state.mn.us>
> I think this needs an RFC... This isn't a trivial addition. For example,
> this mechanism needs to
> apply to stock CGI operations (mode=...) as well or someone could simply
> work around the OWS
> interfaces using their CGI equivalent.
> Which gets me thinking about being able to limit those via a mapfile or
> shut that functionality
> off altogether.
> Steve
> ________________________________________
> From: mapserver-dev-bounces at lists.osgeo.org [
> mapserver-dev-bounces at lists.osgeo.org] on behalf of Daniel Morissette [
> dmorissette at mapgears.com]
> Sent: Wednesday, February 13, 2013 11:12 AM
> To: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] Enable/disable OWS layers by IP list
> Thank you Steve for suggesting the support of subnet masks
> (a.b.c.d/mask), I was going to suggest the same thing.
> I also would like to suggest supporting both a list of addresses from a
> file, or the ability to provide the values directly in the mapfile. In
> cases where there are only a couple of IPs to list, being able to
> specify them directly in the mapfile would be much more user-friendly.
> e.g.
> space-delimited list of addresses:
> "ows_allowed_ip_list" "123.45.67.89 11.22.33.44"
> or ref to a file:
> "ows_allowed_ip_list" "file:/path/to/list_of_ips.txt"
> I think that long term we'll want more powerful access control
> mechanisms, we have discussed this several times here, but that is a
> much bigger issue to tackle and I think the proposed mechanism can
> easily be deprecated without important side-effects the day that we
> would have something more powerful in place.
> And finally, even if that is a simple and straightforward addition, I
> think that a short RFC to document it would be nice and I'd encourage
> you to produce one. RFCs are often the only reference for some features
> until they make it to the docs... there are even some features from a
> few releases ago for which the RFC is still the only/best docs available
> (unfortunately).
> Daniel
> On 13-02-13 10:18 AM, Tamas Szekeres wrote:
> > Hi Steve,
> > Thanks for the comments, using CIDR notation
> > <http://en.wikipedia.org/wiki/CIDR_notation> to define ranges would be
> > reasonable. This would allow to define subnets in a single row. I think
> > it would work with both ipv4 and ipv6 addresses.
> > Best regards,
> > Tamas
> > 2013/2/13 Stephen Woodbridge <woodbri at swoodbridge.com
> > <mailto:woodbri at swoodbridge.com>>:
> > > On 2/13/2013 8:45 AM, Tamas Szekeres wrote:
> > >> Hi Devs,
> > >> I got a requirement from Faunalia (http://www.faunalia.it) to
> > >> establish option to Enable/disable OWS layers by IP list.
> > >> We need to add two new parameters to the WEB section of the mapfile,
> > >> and/or in the METADATA section of every single layer:
> > >> 1. "ows_allowed_ip_list"
> > >> 2. "ows_denied_ip_list"
> > >> Both should point to a file with a list of IP addresses.
> > > If you are pointing to a file then these should be
> > > ows_allowed_ip_file
> > > ows_denied_ip_file
> > > to avoid confusion. Using "list" implies that a item target should be
> > a list
> > > of ip addrs and not a file.
> > > These should not allow parameter substitution as that would be a
> simple
> > > defeat of the mechanism.
> > > Do you plan to support address ranges like:
> > > 192.168.1.1-192.168.1.10
> > > 192.168.1.0/24 <http://192.168.1.0/24>
> > > Otherwise looks fine.
> > > -Steve W
> > >> The aim is to let the admin to define list of users, identified
> > >> through their IPs to
> > >> allow or deny access to one or more specific WMS or WFS layers.
> > >> I've prepared an implementation to this requirement which appears to
> > >> be a fairly simple addition to the code:
> https://github.com/szekerest/mapserver/commit/4b7c203a1782cd56d01c34e1079a184c04e51207
> > >> In my approach if both the allowed list and the denied list contains
> > >> the current endpoint IP then the denied list will take precedence.
> > >> If allowed_ip_list or ows_denied_ip_list is not specified or the
> > >> specified files are not readable then the current behaviour will
> > >> continue to work.
> > >> Issue has also been added for this addition:
> > >> https://github.com/mapserver/mapserver/issues/4588
> > >> Let me know about your opinion whether this change is reasonable.
> > >> Would that require an RFC to be added?
> > >> Deadline of this addition is close, so I'd prefer to include this as
> > >> soon as possible.
> > >> Best regards,
> > >> Tamas
> > >> _______________________________________________
> > >> mapserver-dev mailing list
> > >> mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
> > >> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Daniel Morissette
> http://www.mapgears.com/
> Provider of Professional MapServer Support since 2000
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130214/3a40cb50/attachment.html>
