[mapserver-dev] MS RFC 90: Enable/Disable Layers in OGC Web Services by IP Lists - Call for Comments
Daniel Morissette
dmorissette at mapgears.com
Tue Feb 19 08:20:27 PST 2013
On 13-02-15 12:43 PM, Tamas Szekeres wrote:
> Hi Devs,
> I've prepared an RFC including most of the suggestions received with
> regards to this addition.
> http://mapserver.org/development/rfc/ms-rfc-90.html
> Let me know if you have further things to be taken into account before
> calling a vote on it.
Hi Tamas,
A few questions/comments:
- It is not clear if setting ows_allowed_ip_list implicitly means that
all addresses are blocked, and then only the specified addresses are
enabled, and vice-versa that setting ows_denied_ip_list means that any
address has access by default, except for those listed in the deny list.
I believe this is the implied behavior, but if yes then I think that
should be made clear, and perhaps some examples provided with
explanation of the corresponding behavior.
- Is it possible to set both ows_allowed_ip_list and ows_denied_ip_list
and if yes in this case which one takes precedence? Or do they interact
with each other (i.e. Could I block a range of IPs with the deny list
and then open up specific workstation addresses with the allow list? or
the reverse: open up a range of IP addresses with the allow list and
block a subset with the deny list?)
- With respect to the ms_disable_modes, I don't like a logic where we
need to explicitly list what we block. I prefer the other way around
where we list what we enable to reduce the risk of leaving open holes in
your server configuration.
Actually, perhaps one way to deal with this would be to switch to a
"ms_enable_modes" and use the same kind of logic as ows_enable_requests,
with "!*" meaning disable all, and "!MAP" meaning disable MAP mode, and
then allowing the use of ms_enable_modes at the layer-level as well.
e.g.
MAP
WEB
METADATA
# Block all CGI modes except MAP and LEGEND
"ms_enable_modes" "!* MAP LEGEND"
END
END
END
using inheritance one could then block all modes at the top-level and
re-enable a given mode only for specific layers:
MAP
WEB
METADATA
# Block all CGI modes by default for this mapfile
"ms_enable_modes" "!*"
END
END
LAYER
METADATA
# Enable MAP and LEGEND requests for this layer
"ms_enable_modes" "MAP LEGEND"
END
END
END
or one could be more open by default and selectively disable some
requests at the layer level:
MAP
WEB
METADATA
# Open up ALL CGI modes by default for this mapfile
"ms_enable_modes" "*"
END
END
LAYER
METADATA
# But allow only MAP requests on this layer
"ms_enable_modes" "!* MAP"
END
END
END
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
