[mapserver-dev] ERROR WORKING WITH MAPSERVER
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Feb 27 18:30:43 PST 2013
Make sure /usr/local/lib is included in /etc/ld.so.conf
And then try:
sudo ldconfig
and see if it fixes things.
-Steve W
On 2/27/2013 9:25 PM, reactorh wrote:
> hi,
> I compilded Mapserver and when i try to used it i got this:
> PHP Warning: PHP Startup: Unable to load dynamic library
> '/usr/local/lib/php/extensions/no-debug-non-zts-20090626/php_mapscript.so' -
> libmapserver-6.2.0.so: cannot open shared object file: No such file or
> directory in Unknown on line 0
> when i look for the lub i got this:
> find / -name libmapserver-6.2.0.so
> /root/map/mapserver-6.2.0/.libs/libmapserver-6.2.0.so
> /usr/local/lib/libmapserver-6.2.0.so
> ¨Please could some one help me out with this issue...
> Thx
> View this message in context: http://osgeo-org.1560.n6.nabble.com/ERROR-WORKING-WITH-MAPSERVER-tp5037405.html
> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
