[mapserver-dev] WFS Filter in GET parameter doesn't work with PostGIS Layer
Martin Kofahl
martin.kofahl at gmail.com
Mon Jan 28 00:09:05 PST 2013
Hi Denis,
which datastore do you use? In case of sql, does the database return any
features?
Martin
2013/1/21 Denis Rykov <rykovd at gmail.com>
> Hello!
> $ mapserv -v
> MapServer version 6.2.0
> Trying to use filter with the following URL:
>> http://localhost/cgi-bin/mapserv?map=/home/wfs.map&service=wfs&version=1.1.0&request=GetFeature&typeName=water&Filter=
>> <Filter><PropertyIsEqualTo><PropertyName>natural</PropertyName><Literal>wetland</Literal></PropertyIsEqualTo></Filter>
> But server response looks like:
> <wfs:FeatureCollection xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>> xmlns:gml="http://www.opengis.net/gml" xmlns:wfs="
>> http://www.opengis.net/wfs"xmlns:ogc="http://www.opengis.net/ogc"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver
>> http://localhost/cgi-bin/mapserv?map=/home/rykov/nextgis/vega2013/wfs.map&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=water&OUTPUTFORMAT=text/xml;%20subtype=gml/3.1.1
>> http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
>> <gml:boundedBy>
>> <gml:Null>missing</gml:Null>
>> </gml:boundedBy>
>> </wfs:FeatureCollection>
> Try to debug mapfile by adding DEBUG 5 то MAP section. Accordingly log
> file - no errors, moreover if I change original mapfile with temporary
> mapfile created by MapServer with hardcoded FILTER expression - all works
> fine.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130128/a2957036/attachment.html>
