[mapserver-dev] WFS Filter in GET parameter doesn't work with PostGIS Layer
jbicik jbicik at gmail.com
Tue Jan 29 11:38:46 PST 2013
Hi Denis,
I came across similar response when I did not specify PostgreSQL layer's
extent explicitly in the map file. Might be worth to give it a go to see if
that helps.
Regards, Josef
View this message in context: http://osgeo-org.1560.n6.nabble.com/WFS-Filter-in-GET-parameter-doesn-t-work-with-PostGIS-Layer-tp5028809p5030732.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
