[mapserver-dev] Automated publication of MapServer code coverage
Even Rouault
even.rouault at mines-paris.org
Sat Jul 6 14:52:09 PDT 2013
Hi devs,
What is it about ?
I've setup a cronjob that publishes the code coverage of MapServer when
running the msautotest suite.
The results are published at the below links, and updated at each pushed
commit in master :
http://even.rouault.free.fr/mapserver_coverage_html/home/travis/build/rouault/mapserver/
What for ?
This can help improving msautotest to add better coverage for still untested
code.
How does it work ?
I've setup a branch 'mapserver_coverage' in my mapserver fork :
https://github.com/rouault/mapserver/commits/master_with_coverage
This branch modifies the base .travis.yml to compile mapserver with coverage
information (gcc --coverage flag), runs the testsuite and then generate the
HTML report of code coverage afterwards with the lcov & genhtml utilities. At
the end, it transfers the generated HTML files onto the above site via FTP.
(There's a trick to be able to incrementally upload files between jobs. See
run_code_coverage_upload.sh and find_updated_files.py )
The changes of master_with_coverage vs master are summarized here :
https://github.com/rouault/mapserver/compare/master_with_coverage
The cronjob just merges 'master' into 'master_with_coverage' regularly and
pushes the branch to github, which causes a Travis build.
Why in a personnal branch ?
The issue is with the FTP transfer onto my HTTP page. This requires of course
specifying a password that is better kept private... Travis offers a way of
doing this securely by putting an encrypted environment variable into the
.travis.yml file. When Travis runs the script, it decrypts the environment
variable. The variable is encoded/decoded with information linked to the
Travis (or github ?? I'm not sure) account. There's a security in Travis that
prevents people running forks of the repository (or pull requests triggering
Travis builds) to steal the decoded information. See http://about.travis-
ci.org/docs/user/build-configuration/#Secure-environment-variables for more
details.
This could likely be merged into the official MapServer repository (this would
avoid relying on the cronjob on my PC) if the project manages a FTP
repository. I've not investigated if there would be more efficient/simple ways
to upload files.
Best regards,
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
