[mapserver-dev] Change in msProjectionObj2OGCWKT() to use OSRImportFromEPSG() when possible
Even Rouault
even.rouault at mines-paris.org
Sun Jul 7 11:11:01 PDT 2013
I've prepared the following pull request :
https://github.com/mapserver/mapserver/pull/4695
This changes msProjectionObj2OGCWKT() to use OSRImportFromEPSG() when possible
(i.e. when the projection is defined as +init=EPSG:XXXX).
This helps when using OGR OUTPUTFORMAT with some formats that need an EPSG
code to be explicitely set in the OGRSpatialReference object.
The updated tests are there :
https://github.com/mapserver/msautotest/commit/303ae5e8b04ee51c19a98625546e3a8ddc26bc03
One can notice a few changes in some WFS OGR output that show the benefit of
having the EPSG code set.
This also causes a number of updates in the WCS test-suite : they are due to
the citation part of the SRS encoded in GeoTIFF being drawn now from the EPSG
database instead of the name that PROJ.4 tried to build (and that is often
inferior).
Any objection to my applying this ?
Best regards,
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
